DanMar Posted November 5, 2004 Share Posted November 5, 2004 Have to locate, replace starter/sol. Easy or hard? Thanks Quote Link to comment Share on other sites More sharing options...
lmdew Posted November 6, 2004 Share Posted November 6, 2004 Just follow the + wire from the battery back to the Starter. Two bolts hold it on. Make sure you disconnect the negative battery cable first! Quote Link to comment Share on other sites More sharing options...
DerFahrer Posted November 6, 2004 Share Posted November 6, 2004 Easy, super easy. I can do it in 20 mins. If you're looking at the engine facing the vehicle (driver on your right, pass on your left), and the front of the transmission is a clock, the starter is sitting right around 2 o'clock. Once you see it, you can't miss it. Just pull the wires and remove the bolts (you'll need an extension for the bottom one) and installation is the reverse. And yes, pull your - battery cable. Quote Link to comment Share on other sites More sharing options...
swilde20 Posted November 15, 2004 Share Posted November 15, 2004 it seems to be easiest to take off the top bolt and jackup the car and takeoff the other bolt from underneath the car. it only took me about 25 min. to change mine. make sure to disconnect the negative battery terminal first. Quote Link to comment Share on other sites More sharing options...
