?? does a FORD PINTO carb replace... :brow:
subiemech85
an ea81 carb?? I'll see about that, they both have hitachi chokes, appear to have the same bolt pattern, and are made in JAPAN
Only major preliminary differences is the float level window is 10x larger on the ford, and it uses a round air cleaner
:banana:
It's possible. Let us know.
I do know that many Nissan pickup trucks used a larger Hitachi carb that bolts directly to a EA82 intake manifold, which in turn bolts directly to an EA81.
Throttle plate sizes are as follows:
EA71/EA81 = 26mm/30mm
EA82 = 28mm/32mm
Nissan Truck = 30mm/34mm
Also Mazda trucks used Nikki carbs that have similar mounting patterns, but I've never test fit one of these. Isuzu trucks use either the large Hitachi, or the Nikki, but I can't remember which.
I've always wanted to try one of these as a cheap alternative to a Weber, but I keep getting sidetracked with other projects.
yeah ,but doesn't the manifold of an ea82 bolt right on the ea81.....?i think that is what he was getting at.i have been looking at carbs alot lately and it seems to me that there are alot of base patterns extremely similiar on the older nissans and toyotas.i even saw an early seventiescorona hatchback...yes i said corona hatchback.....with virtually the same base pattern and hitachi carb on it .even though something just wasn't right about the carb,weird secondary setup on it,i bet it would fit.
Right. The larger carbs only bolt up to EA82 intake manifolds because they both use the longer bolt pattern. But an EA82 manifold will bolt onto an EA81 (with a clever trick to get the disty to clear the EA82 thermostat housing).
no, it is more than just clearing the dist
you have to extend various wires, coolant temp, oil pressure, etc.
swap throttle cable bracket
remove and plug the bypass line that goes to the t-stat housing,
reroute bypass lines
remove the tab by said bypass line
remove metal on alt bracket
mix n' match emissions lines
use ea82 upper rad hose, air box and other tidbits
trust me, I've done it
I did NOT do anything to the dist.
quit HIJACKING this thread
  • 11 months later...
I think the hovercraft people with universial hovercraft plans that use a ea81 suggest using a ford escort distributer with regular points so to do away with the more complicated edi.
Some of the people who fly Subarus', I'm not sure if its the ea81, 82, or ej, use a 2 barrel rockchester for the increased demand for fuel flying.
