87 wagon fuel lines? carbed motor....
maybe I should clarify.... which ones come from which section of the firewall?
I can put a ea81 back together in my sleep, but this is my first time working on a ea82 body,and there's no motor or intake to speak of, and all emmissions stuff is gone too.
it will be getting a ea81 with a weber.
ok, the tiny one near the top of the firewall is the return line. the bigger one right next to it is the vent line that goes th the canister. the fuel feed line is the one under both of those hoses, a few inches down.
hope that helps. pics later if it doesnt.
sounds like mine. found the 2 up top. small one, and a larger one. the big one below is right above the frame rail on mine...
I got the motor in tonight, but still need to hook up the exhaust, install the weber/fuel lines, and figure out the wiring... getting closer....
