subaru legacy transmission dipstick
does anyone know where the transmission fluid dipstick is on a 2000 subaru legacy gt limited....i can't find it...the manual says it is to the left of the air filter but i can't find where it is located...any help would be greatly appreciated. :)
Transmission dip stick is behind the engine in front of driver side firewall. Move a few hoses out of the way, look down and you'll see it has a yellow top.
Other side (passenger) lower down yet, again move a few hoses aside, yellow top handle, you'll find the shorter differential dip stick.
In either case, if your gaze reaches the ground, you've gone too far. :banana:
