WJM Posted November 11, 2004 Share Posted November 11, 2004 Im so pissed. Link to comment Share on other sites More sharing options...
calebz Posted November 11, 2004 Share Posted November 11, 2004 What happened this time? Link to comment Share on other sites More sharing options...
WJM Posted November 11, 2004 Author Share Posted November 11, 2004 What happened this time? Well, first, I was playing with my enrichen'd mixture and ejoying massive clutch slip at 12 PSI when my rear suspension broke and I had to limp it home. So...after spending 2 hrs replaceing that with stock RX units and uprated/short spring...I was back out on the road...12 PSI...oh NOES! power dissapear...smoke everywhere. Stop, pull over...oil everywhere. Oh, the dip stick popped out again. Ok...back in...crank...no crank...slow slow slow...FInally, after mahing the gas it fired to life...sligh knocking noise...low power. GRRR. SO, flog it back home...post this...put it in on the concrete pad to rip all the suspension off so it can go on the RX...REV to 7K at 14 PSI (floored, no load) HOld it for a few mins...and it wont blow up. It wont idle. Its knocking like crazy and spitting oil everywhere. I think im done with EA82T's for a while. Link to comment Share on other sites More sharing options...
DerFahrer Posted November 11, 2004 Share Posted November 11, 2004 Its knocking like crazy and spitting oil everywhere. I think the fat lady just sang... Link to comment Share on other sites More sharing options...
Snowman Posted November 11, 2004 Share Posted November 11, 2004 Geeze that's a bit of a setback. Do you know what happened? Yeah, it's frustrating (I had my rebuild blow up after 5k the first time), but you can't give up, man! Find out what went wrong, fix it, and make it faster. If anybody can do that, it's you. Don't give up! Link to comment Share on other sites More sharing options...
northguy Posted November 11, 2004 Share Posted November 11, 2004 Now is when the learning process really begins. Good luck with it. Link to comment Share on other sites More sharing options...
DrKrazy Posted November 11, 2004 Share Posted November 11, 2004 I think im done with EA82T's for a while. ACK!!! That's not what we want to hear coming from you WJM! Maybe someone else but you?!? Come on now, wasn't this a thrown together 170k+ motor? Shoot I'll give you the 200k+ motor out of my RX if you want another of one of those. Runs fine just a bit of lifter noise and some coolant leak from an exhaust bolt. Kabooms tend to happen to 170k motors at 12psi I would think. I have faith that you are the man to get it back on the road in no time though. Link to comment Share on other sites More sharing options...
4RnrRick Posted November 11, 2004 Share Posted November 11, 2004 ...REV to 7K at 14 PSI (floored, no load) HOld it for a few mins...and it wont blow up. .... Link to comment Share on other sites More sharing options...
WJM Posted November 11, 2004 Author Share Posted November 11, 2004 Hey now! THat was after the fact! Fact=smoke everywhere and it woulndt go no more Link to comment Share on other sites More sharing options...
Caboobaroo Posted November 11, 2004 Share Posted November 11, 2004 so any thoughts on what you blew? You just said oil everywhere but not from where..... so is this now Subaru:20 million, WJM:0:clap: Link to comment Share on other sites More sharing options...
subiemech85 Posted November 11, 2004 Share Posted November 11, 2004 looks to me like the turbo puked the wastegate, what else would explain the location of oil? Link to comment Share on other sites More sharing options...
4RnrRick Posted November 11, 2004 Share Posted November 11, 2004 Hey now! THat was after the fact! Fact=smoke everywhere and it woulndt go no more I understand that it was broke, but I don't understand why you wanted to break it more! :-\ Link to comment Share on other sites More sharing options...
JWX Posted November 11, 2004 Share Posted November 11, 2004 I understand that it was broke, but I don't understand why you wanted to break it more! :-\ why not, whats he going to save it for? Link to comment Share on other sites More sharing options...
Subi81 Posted November 11, 2004 Share Posted November 11, 2004 Sorry to here that. Engine campartment looks like a total mess. Still don't understand why it is blowing oil? Compression leak? over filled? Link to comment Share on other sites More sharing options...
WJM Posted November 12, 2004 Author Share Posted November 12, 2004 Rings were already almost shot when the engine was put in (170K miles of abuse by prev owner...and 1000 miles of racing abuse in my other RX) So...my guess...is that the rings on one piston totally went...but then agian...i found some chucks of piston metal...which makes me think a piston melted due to poor injector spray pattern...as Ive got those modded injectors installed. Link to comment Share on other sites More sharing options...
JWX Posted November 12, 2004 Share Posted November 12, 2004 so this might not have been the engines fault? and man you need to get a wide band asap just to make sure. or hell just a reg Air/fuel gauge might work Link to comment Share on other sites More sharing options...
WJM Posted November 12, 2004 Author Share Posted November 12, 2004 No no....remember what the cylinder walls looked like? The history of the engine? No...I added a little fuel...that should not cause the blow up. But the injectors might have helped....stilll....reember the crap taht came out of the block? Link to comment Share on other sites More sharing options...
MorganM Posted November 12, 2004 Share Posted November 12, 2004 It's all guesses untill you tear it down. I love tearing down blown up motors and finding out what happend. Hope you find a new core to work with soon! Link to comment Share on other sites More sharing options...
