Caboobaroo Posted November 11, 2004 Share Posted November 11, 2004 well my waterpump in my RX is like totally shot so I was calling around on prices and one place said that there's a difference in them height wise. The shorter one is more expensive then the longer one. What would my '89 RX have? The shorter one or the longer one? Another place I called asked if it was a coupe and I said yes and there were no different length waterpumps that I had to choose from, just a new one or a remand one. What a weird day.... Link to comment Share on other sites More sharing options...
All_talk Posted November 11, 2004 Share Posted November 11, 2004 From what I understand, its with or without A/C, but I dont remember which goes with which for sure and if it applies to factory A/C only or the dealer instaled type aswell (A/C pump outside alt.). I do know that when I bought thw water pump for my '87 GL wagon (no A/C) the parts guy said one is much more common, so I got that one and it fit (I still have the old pump if you want me to measure it). Sorry I can't br more help, I'm sure someone knows more Gary Link to comment Share on other sites More sharing options...
NorthWet Posted November 11, 2004 Share Posted November 11, 2004 I did a quick eyeball-check of 2 '87s: one T with A/C, the other SPFI w/o A/C. Rough check from above shows both the same length (within 1/4 inch parallax error). Another absolutely certain "maybe". Link to comment Share on other sites More sharing options...
Subi81 Posted November 11, 2004 Share Posted November 11, 2004 I got one for an 87 spfi with A/C that is LONG one on my 86 Twagon with A/C is SHORT. Didn't realize until I installed the pump the accessory pullys whouldn't line up, a quik trip to the jy fixed the problem. just had to get a 4 Bolt Pully My turbo wagon had the pully with 8 bolts = SHORT PUMP SPFI had pully with 4 bolts = LONG PUMP I guess technically they are studs off of the Water pump Hope this helps Good luck. Link to comment Share on other sites More sharing options...
Caboobaroo Posted November 11, 2004 Author Share Posted November 11, 2004 well my waterpump has 4 studs coming out of it. Thats the only style I've seen on any EA82 motor. I've done work on an '86 turbosedan, an '87 turbowagon, an '86 XT4 MPFI nonturbo, and a few others. Do you mean on your waterpump that it has 8 studs coming out of it instead of 4? Weird..... Link to comment Share on other sites More sharing options...
stngllhm Posted November 11, 2004 Share Posted November 11, 2004 if the pulley on the water pump has though holes<in other words if the fan bolts to the studs that are on the water pump> you need the taller waterpump if your pulley has four studs attached to it for the fan you need the stort one. make any sence Link to comment Share on other sites More sharing options...
Caboobaroo Posted November 11, 2004 Author Share Posted November 11, 2004 ahh ok so I'm going to need the taller one since my pulle has 4 holes in it, and when I ut it on the pump, the studs stick out quite a ways... Link to comment Share on other sites More sharing options...
sandman Posted November 11, 2004 Share Posted November 11, 2004 I took mine to the parts store with me and compared them. Mine was the taller version. Link to comment Share on other sites More sharing options...
XSNRG Posted November 12, 2004 Share Posted November 12, 2004 Caboo, that's good info above. Of all the turbo cars I've had, all had the long pump BUT the pulley will tell you for sure. Stamped pulley with holes = long pump, cast pulley with holes and studs = short pump. Link to comment Share on other sites More sharing options...
Caboobaroo Posted November 12, 2004 Author Share Posted November 12, 2004 thanks for all the helpful info guys! Now I can go get me the cheaper waterpump;) Its like 20.69 or something about that:D Link to comment Share on other sites More sharing options...
