AKIRA Posted November 12, 2004 Share Posted November 12, 2004 I have a problem with the engine parts for my brat, they.... don't fit at least some of them don't, I got a dist. cap that won't fit on, and the exhaust gasgets don't fit either. (I got them for an "84 Brat GL non-turbo" see what happened is, back in 1995 a 68,000 mile engine was put in it (I know this from the service records) , but I am not sure from what year, or model of GL. how would I check to see what year of engine it is? Link to comment Share on other sites More sharing options...
Will Smith Posted November 12, 2004 Share Posted November 12, 2004 nice looking Brat. take your old rotor into the parts store and have them match it up. the parts folks should be able to find the cap and exhaust gaskets from the application crossover. Link to comment Share on other sites More sharing options...
AKIRA Posted November 12, 2004 Author Share Posted November 12, 2004 that is a good Idea, I woudn't have thought of that. is there any other way to tell, like the number on the engine? (is there one?) Link to comment Share on other sites More sharing options...
Caboobaroo Posted November 12, 2004 Share Posted November 12, 2004 I bet ya its probably a motor from a 2wd car. The 2wds had a different disty and thus having a different cap and rotor. I would have to agree by taking them into a parts store and having them match them up but I bet ya a million bucks that its a 2wd disty... Link to comment Share on other sites More sharing options...
AKIRA Posted November 12, 2004 Author Share Posted November 12, 2004 were nippon denso's the 2wd ones? because thats what it is Link to comment Share on other sites More sharing options...
CIS Subaru Posted November 13, 2004 Share Posted November 13, 2004 were nippon denso's the 2wd ones? because thats what it is Yes. I think the ND disty was standard on any EA81 with an O2 sensor. (not that the two are actually related) My '88 4wd Hatchback has the ND disty and an O2 sensor, as do all of my 2wd EA71/EA81 cars. In general though, 4wd cars got the Hitachi dist, while 2wds got the ND one. In what way did the exhaust gaskets not fit? and which exhaust gaskets? The "flange" gaskets between the Y-pipe and the heads are the same for all EA71/EA81/EA82 cars. I guess the diameter of the hole in the middle might vary some, so I always use EA82 ones on all of my cars. If you asked for "exhaust manifold" gaskets and got gaskets that look like large thin washers, those are the ones that go between the cast iron air pipe flange and the head. Any other exhaust gaskets can vary depending on year and if you have a stock exhaust or not. Link to comment Share on other sites More sharing options...
AKIRA Posted November 13, 2004 Author Share Posted November 13, 2004 it's a 2wd model engine, I took the cap down and found a replacement. The gasgets are not the same, I mean the gasgets that connect the y-pipe to the heads, what I got looked just like the gasgets that were on it, but the bolt holes were a little too far apart, I had to cut out a small piece to make it fit, but that, with the need for new bolts/nuts there, makes it loud Link to comment Share on other sites More sharing options...
Dr. RX Posted November 13, 2004 Share Posted November 13, 2004 it's a 2wd model engine, I took the cap down and found a replacement. The gasgets are not the same, I mean the gasgets that connect the y-pipe to the heads, what I got looked just like the gasgets that were on it, but the bolt holes were a little too far apart, I had to cut out a small piece to make it fit, but that, with the need for new bolts/nuts there, makes it loud And where did you get these parts?? Some general auto parts store or a Subaru dealer. It sounds like you got the gaskets (note spelling) for an EA82, they are very similar looking, but the spacing is different. Link to comment Share on other sites More sharing options...
AKIRA Posted November 13, 2004 Author Share Posted November 13, 2004 I got them at a local place in-town. those are for what he said goes to a 1981 brat, beause the ones he had listed for an 84 brat were these soft metal ring things. (???) I know he has no idea what he was doing, I forgot that when I listed it earlier. Link to comment Share on other sites More sharing options...
AKIRA Posted November 13, 2004 Author Share Posted November 13, 2004 I went to advance auto, they didn't have any gaskets for it Link to comment Share on other sites More sharing options...
operose Posted November 14, 2004 Share Posted November 14, 2004 my mom's a manager at advance auto... and I try not to go there. but it's hard when you get a 15% discount.. to be truthful, though, they are a stupid, evil place that generally doesn't know anything about what they do (based on the employees in the two stores mom has worked at) Link to comment Share on other sites More sharing options...
heartless Posted November 14, 2004 Share Posted November 14, 2004 Sorry, but I have to Disagree with the "idiot" thing at Advance Auto...The one we have here has a couple of VERY knowledgeable employees, one of whom even offered to let me use his personal compression tester when we had a no-start issue a while back - the store was "out of stock" at the time. I guess whether or not you have idiots behind the counter will vary from location to location, but the one here is pretty well staffed - thank goodness!! and thier prices beat the other two "auto" parts stores in the area. (and the nearest Subaru Dealer to me is a 3 1/2 hour drive one way - not something I can do on a regular basis!) Link to comment Share on other sites More sharing options...
