EA82T throttle position sensor adjust?
well that did absolutely nothing.
tried to do emissions yesterday, and it wouldn't idle steady above 2300rpms, just dropped. it's kind of choppy to drive, throttlewise.
still does it no matter where the TPS is set at. i think it has something to do with no engine compression and the turbo kicking in around 2300 or so.
*kick*
engine cold works fine you say ..
sounds like it might be a partially faulty tps then maybe
after all teh heat from the motor reaches parts and they expand even a tiny bit.. then well teh tps no longer functions right.. just a guess
eitehr check the volts at teh terminls when its cold and running and then recheck when it hot and running and if its a alot of change.. then try a diffrent tps
or check for crappy grounds on the engine block /heads/intake
it might be a crappy ground losing contact when it warms up
add a few extra grounds for fun it certainly won't hurt :)
