Front suspension bushes '91 Legacy
I'd probably replace the anti-sway bar bushings with polyurethane ones, as well as get new end links. The front bushing on the control arm is pressed in, and you'd need a press for that. I'm not sure of any aftermarket bushings for that one. The rear bushing on the control arm should be able to be removed without taking off the control arm.
I'd suggest talking to whiteline and see what they can offer you.
