Wheel scrapes caliper
:confused: My 88 gl wagon's front pads were down to about 1/16" of friction material, so I got me a set of them thar new pads and new rotors. Put it all back together and now the calipers have "floated" outboard to the point that they scrape the stock 13" wheels. I put a washer over each wheel stud to space them out (about a 16th of an inch) and it is enough to relieve the scraping, but that is not a good fix, has this happened to anyone else, and what could I have done wrong?
I had the same problem after replacing the disks and pads. I didn't measure the thickness of the disk, but suspect that the fine Chinese replacements I used are thicker than they are supposed to be. You might try painting the calipers then looking where paint gets rubbed off by the wheel; use an angle grinder to take off a little material at the rub points. I did this, and it worked for me.
- James B
'85 4WD DL wagon
'01 2WD Nissan Frontier
'95 Casita FD
