WJM Posted November 16, 2004 Share Posted November 16, 2004 The lines I am selling...looks like with a slight modification to the banjo bolt and they will work for the rear. They will have to be routed differently...but nothing a zip tie could not fix to keep it stable. I test fit this to to a junked rear suspension i have...jsut a matter of mod'in the banjo bolt and applying it on the RX...!!! Link to comment Share on other sites More sharing options...
Numbchux Posted November 16, 2004 Share Posted November 16, 2004 I was looking at mine, and the rear disc setup I just bought, and was wondering if it would work, but I'm not anywhere near my car, so I have no clue what the other end looks like. hmmmm....maybe I should get that other set from you, probably not. Link to comment Share on other sites More sharing options...
WJM Posted November 17, 2004 Author Share Posted November 17, 2004 If this set does not sell by tomorrow evening...I am keeping them and doing the little conversion on the banjo bolt and install these on the RX. Link to comment Share on other sites More sharing options...
JWX Posted November 17, 2004 Share Posted November 17, 2004 what needs to be modified? Link to comment Share on other sites More sharing options...
WJM Posted November 17, 2004 Author Share Posted November 17, 2004 what needs to be modified? The rear...the lines goes stright into the caliper...no banjo bolt. that rubber line goes to a steel one...that one to another rubber one that goes to the steel line on the body at the crossmember for the rear suspension. The BSS line...if the banjo bolt is shorten'd by 2~3 MM, will seal the caliper end of the line correctly with the copper washers, and is long enough to replace the two rubbers and steel....and bolt up to the stock holder where that last rubber one goes to the steel one at the crossmember. Link to comment Share on other sites More sharing options...
JWX Posted November 17, 2004 Share Posted November 17, 2004 could you get a spacer (washers) and do that with it instead on cutting the bolt? Link to comment Share on other sites More sharing options...
WJM Posted November 17, 2004 Author Share Posted November 17, 2004 could you get a spacer (washers) and do that with it instead on cutting the bolt? Maybe. I wont be able to try it tho...speedy got the lines. I will do this before next season starts. Link to comment Share on other sites More sharing options...
JWX Posted November 18, 2004 Share Posted November 18, 2004 just try it with a set of stock front ones, or tell me which connection to use and I'll try it on the 89 since its not driving Link to comment Share on other sites More sharing options...
