bgambino Posted November 16, 2004 Share Posted November 16, 2004 OK Bought a 91 4WD Loyale (automatic wagon 1.8 NON-turbo) about a year ago....drove it home(about 40 miles) and ran fine. Parked it about a year Started it now and then. ready to put on the road so I did timing belts, cam shaft seals, plugs cap and rotor. Started and ran fine...drove it and the check engine light came on---box under dash was blinking 3-2 (oxygen sensor?) and 3-5 (purge control solenoid?). Next time I test drove it (a few days later...the check engine light starts BLINKING and the under dash box is giving me 7 fast blinks repetitively. A week later I test drive it----and the light comes on---and now I have SIX codes blinking!!---32,33,42,45,51 and 61...what the heck is going on?If I start it and just let it idle for a while....engine light stays off but box is blinking 7 fast blkinks Except for a little bit of rough idle during cold starting ,,,,car seems to run good (have not insured it nor driven it a lot--just test drives of 4-5 miles). Also...have a rythmic sound which I am guessing is a bearing but how can you be sure ...and which wheel?...turn steering wheel slighly to right and its a little louder...turn slightly left and a bit quiter thanks Bill Quote Link to comment Share on other sites More sharing options...
baccaruda Posted November 16, 2004 Share Posted November 16, 2004 here's something that may help http://www.westol.com/neper/ecucodes.html don't thank me, thank skip (that's his site) good luck. oh yeah. make sure your car's electrical grounds are good. do a search for "ground" and you'll find some good info there too. Quote Link to comment Share on other sites More sharing options...
bgambino Posted November 25, 2004 Author Share Posted November 25, 2004 well...the trouble code problem was simple and stupid...someone had the green connectors plugged together(one of the trouble code connectors--maybe the diagnostic one!) thanks for all the help...especially skip! still have what I think is frt wheel bearing noise...and of course you cannot really tell which side...I hate that job! Quote Link to comment Share on other sites More sharing options...
