Ross Posted November 17, 2004 Share Posted November 17, 2004 Hi all, looking for some advice regarding the ea81t engine. i am looking at replacing my 81 GL wagon, as it is rusting to pieces, and i am sick of welding the thing. Found a 83 turbo wagon, only two owners and no rust whatsoever. Just wondering what these engines are like for reliability, and whether i would be best to dump my non turbo motor in it? Also, i would be swapping the auto for my 4 speed, will i need to swap the diff etc as on the ea82 models? Link to comment Share on other sites More sharing options...
ccrinc Posted November 17, 2004 Share Posted November 17, 2004 Extremely reliable. If you do the 2 things every Sube owner must (change oil religiously, and never, ever, under any circumstances let it overheat), it should run as long as the non-turbo version. Emily http://www.ccrengines.com Link to comment Share on other sites More sharing options...
subiemech85 Posted November 17, 2004 Share Posted November 17, 2004 if it smokes, it may be the seals in the wastegate, no big deal good move replacing the auto, it's crap Link to comment Share on other sites More sharing options...
Turbone Posted November 17, 2004 Share Posted November 17, 2004 If you do drop the 4spd in, make sure you replace the clutch with the best and strongest you can get. The 4spd doesnt like the torque from the turbo Hopefully the engine has the upgraded turbo, with water cooling. Link to comment Share on other sites More sharing options...
subiemech85 Posted November 17, 2004 Share Posted November 17, 2004 ea81 had NO water cooling ea82 does have water cooling Link to comment Share on other sites More sharing options...
Turbone Posted November 17, 2004 Share Posted November 17, 2004 I beg to differ. The 84 T-Coupe I sold to Mr. Carb has it, and I have had 4 others that were also. When they first came out they were not water cooled, then the dealers called them back (not a recall) and refitted them with turbo's that were watercooled. Link to comment Share on other sites More sharing options...
CHIM Posted November 17, 2004 Share Posted November 17, 2004 I beg to differ. The 84 T-Coupe I sold to Mr. Carb has it, and I have had 4 others that were also. When they first came out they were not water cooled, then the dealers called them back (not a recall) and refitted them with turbo's that were watercooled. Not sure of wich ones got it for why, but my 84t wagon has a water cooled turbo. Does anyone know if any after market performance injecters are availible for the EA81 turbos? Link to comment Share on other sites More sharing options...
MSSLGECKO Posted November 17, 2004 Share Posted November 17, 2004 Mine is very reliable. Make sure the cooling system is up to par (mine is not currently) I don't know of any injector upgrades Link to comment Share on other sites More sharing options...
Turbone Posted November 17, 2004 Share Posted November 17, 2004 You can also upgrade the turbo by replacing it with one from a EA82T. Just make sure you use the crossover pipe and downpipe. Link to comment Share on other sites More sharing options...
CHIM Posted November 17, 2004 Share Posted November 17, 2004 is there any advanteges from running an EA82 turbo? Given that one already has a Watercoooled EA81 turbo? Link to comment Share on other sites More sharing options...
Turbone Posted November 17, 2004 Share Posted November 17, 2004 From what I understand (and a little seat of the pants), its a hair bigger. Link to comment Share on other sites More sharing options...
calebz Posted November 17, 2004 Share Posted November 17, 2004 Yup. EA81 uses a VF4(?) EA82 uses a VF7 Link to comment Share on other sites More sharing options...
MSSLGECKO Posted November 17, 2004 Share Posted November 17, 2004 Do you have to use the DP and cross over pipe from the EA82T to use the turbo? Link to comment Share on other sites More sharing options...
bajavwnsoobnut Posted November 17, 2004 Share Posted November 17, 2004 Turbone I think there was a recall on the non-watercooled turbo's and they just replaced the centersection with a the one with watercooling and CHIM the difference is a lil bit bigger turbo and also you have an easier time finding a turbo if that one goes bad and also better exhaust choices sorta Link to comment Share on other sites More sharing options...
Turbone Posted November 18, 2004 Share Posted November 18, 2004 Thanks for repeating what I already said Baja Link to comment Share on other sites More sharing options...
bajavwnsoobnut Posted November 18, 2004 Share Posted November 18, 2004 sorry Rob but I didn't see page 2 and also there was a Official Recall on that not a dealer call back Link to comment Share on other sites More sharing options...
