87 Lifted Wagon resurrection progress.... still waiting for engine .... pics
if any of you remember this post from January....
http://www.ultimatesubaru.org/forum/showthread.php?t=9555
Well anyway, I got it from Chef Tim, and have been working on making it my daily driver.
I have done the following so far:
resealed EA81 with 86k miles from a 83 Brat
valves adjusted
rebuilt a water choke weber 32/36 and installed it
rebuilt disty from eBay
new ea81 radiator
ea81 radiator fan
ea81 power steering pump (after this weekend)
new clutch kit for the 5 speed
different starter
replace heater core (in progress)
new MSD coil/wires
replacement right rear tail light
other stuff planned:
RX black checkered front seats.
RX checkered seatbelts
Yakima Load Warrior Rack
had it running last night, but had to keep on the gas. once the core swap is done, will need to check the timing...
got the core in tonight, and got the dash all back together! what a pain....
still have to hook up the hoses.
since I had the front seats out, I started to put in my checkered RX seatbelts. got the 4 center rear pieces in. just have the outside ones front and back to go.
Tim,
just a stock rod, but that's a maybe. I got a bracket from Turbone. still unsure how it's gonna work on the ea81 engine. (How did you do yours?)
looks like I'll be pulling the RX belts our from the back seat. they don't roll properly. the parts look identical (same numbers too), but it keeps locking up.
I won't be working on it again until next week sometime.
I did get most of the RX seatbelts in. the front went in without issues, and for the back seat belts, I used the RX center belt pieces, and the RX recievers, but had to use the wagon side retracters. had to tweak the hole a little, but all works fine now....
next some removeable carpet pieces. though this is gonna be my daily driver, I still want to have it off-road ready... had thought about putting stock carpet back in, but decided against it....
why does everyone love the rx seats so much? have you not seen xt6 seats!? they are muy more classy. muy muy! and very comfortable.
come up here and sit in my wagon with them you might be hooked =]
I've got the red "pimp" seats in front right now. they are identical to the RX seats I have, but all cloth. they have the height adjust too.
I have had a set of XT seats before, but they reeked of mouse piss!!!!
the red ones will do for now. Thinking about getting the covers fixed on my RX seats. I like the black/white checkered flag look :)
what are ya doin for the back seat? I've got a complete set of the checkered seats but noticed that a sedan seat is different than the wagon because of the fold down part.
for now, the back seat is staying as is. it's perfect shape, but it's brown. will be good for now. next spring I'll decide on if I need to go back to gray or not... :)
It's okay Caleb, I wasn't going to let Radio go anywhere except the best of homes. Micky do you still need that pitching rod bracket?? Tim
Tim,
I got mine in fine. I used the bracket from Turbone, and some square tubing to raise the bracket up because of the EGR valve. fit's perfect with the Extended Rod I had.... so I for sure don't need a stock pitching stopper rod...
I decided to go carpetless for the winter. put in some deep rubber mats, and got the seats cleaned up and back in. Even the sheepskin cover... :)
Got the stereo amp in and a CB installed.
Also got the PS pump put on, and will be trying to get fittings for the PS lines today.
Left to do:
PS pump belt & hoses
Radiator Fan
Reset Timing
put heater core into coolant loop.
swap wheels so I can get my new tires...
Install Yakima Rack.
Clean rear cargo area
Fog Lights
I ended up just getting a new PS line made with the old fittings. bottom fitting from the EA82 PS line and top fitting from the EA81 PS line. fittings were cut and welded to new stems, and new hose and crimps added...
for the PS return line, I just used the stock EA82 PS return line. it's a bit long, but will work fine :)
I'm looking forward to PS again. haven't had it since I sold Mountain Grizzly.....
it really won't look much different than how it looked when Caleb had it. (well, the engine bay will be a lot different..... :) )
I found another pic of it on the revamped HP site...
almost forgot. I'm putting on my old brushguard too from my Brat... the fogs will mount to it....
it's alive!!!!
had to reset the disty, and change my ea81 radiator mounting so I could fit the fan in. just need to add some PS fluid (why does my cap say use ATF Dexron?) Then I'm ready to get the new treads :)
gonna need a windshield too.....
cleaned out the cargo area last night and put in my MTX RT boxes.... there's more room between the rear wheel well in an ea81 wagon !!!! I couldn't put the boxes side by side there like I did in my 82... ended up putting them along the sides at the far back of the cargo area.
a little Febreeze on the seats/cargo carpet too.
took of the small bra on the front of the hood. and added PS fluid.
got my 14" alloys on. new tires will get put on next week hopefully.
225/70R14 http://www.lemanstire.com/tires/catalog/lemans-at.jsp
replaced broken right rear tail light.
have brushguard temporarily mounted with big screws into the rubber bumper :lol: but figured out how I can do a proper mount though...
looks funny though with the "shelf" bumper :) but it's a nice place to put tools while your working on it :grin:
I should be able to get some pics of it this weekend....
it's dead (well, actually dying...)
majorly bummed.
anybody close to IA have a spare ea81?
cylinder #3 bad. either the piston or connecting rod bolts.
will be swapping heads to a different shortblock.... sometime in January....
fun fun fun....
Aw man that really sucks :(
I saw two EA81's at a local junkyard if you are interested. Been a few weeks now though... hopefully they didnt get crushed yet :-\
nah. got something lined up already :)
but on a good note, I was able to drive it long enough to burn out all the coolant that got into the exhaust when the previous ea82 blew the HG....
bet that was a site as this soobie was followed by a humongous white cloud.. at about 1 AM too :lol:
and I had forgotten how good the side bolstered RX type seats felt :)
