Concerns for too much ATF fluid?
How are you checking the level?To properly check the level, the transmission fluid needs to be at normal operating temp. Driven around for a couple miles. Park the car on a level surface, slowly cycle the gear selector from park to 1st and then back to park. Leave the engine running, and then check fluid level.
