oil change and oil pressure question
hello
i hope someone can give some insight into this.....
Bought my car about two months ago
'90 loyale wagon 5sp push button 4wd 262,000 K
I just changed my oil
{about an hour ago}
used high mileage oil and filter
added that 'valve medic' stuff
{the TIC was driving me crazy !!}
seemed to work great !!!
prolly only for a little while, but thats better than nothing !
only problem i noticed
my oil pressure isn't as high as it was before ?
any ideas ?
should i be concerned ?
it's still not bad just not as high as it was
was around 3
now around 2 or a bit more
goes up a bit when you rev it real high
but with normal driving
it now seem lower
heres to hoping i'm just over reacting !!
If it's ticking quite a bit, then the oil pump seals have failed. They deteriorate and allow air to get sucked in, or something. The result is lifters that won't pump up and bad oil pressure.
Search for "oil pump seal" and you should find some results.
BTW the guages aren't real accurate.
i'm sure the oil pump seal is going
i just don't have the money to do it right now
but would the oil filter really cause that much of a difference ?
it's a high milage filter
id'e of thought that would be better
on the other hand
its supossed to filter out more junk
so maybe its slowing down the whole system ??
Replace the filter. Use only the Subaru one.
I'd also use 10W40 oil in that engine. Get Quaker State at Canadian Tire. Use 20W50 in the summer.
On my Subarus, (I've had 4 that all went over 400,000 km), lifter ticking occurred only when it was time for an oil change. I always changed the filter at the same time. None of them ever needed work on the oil pump.
my 86 spfi a/t fwd sedan started ticking really bad , and yes subaru did make a spfi in 1986 but only fwd and in a sedan , anyways i decided to change the oil to chevron 15w40 , within 100 miles the ticking was gone , and good oil pressure just like before the ticking :cool:
