subyrally Posted November 18, 2004 Share Posted November 18, 2004 the hi-beam switch is in neutral position, but both filaments on the bulbs are lit, hi and lo at the same time. and when that happens, it tries to burn the fusable link for the lights. any one know of a fix for this or happen to have an extra 86 hi beam switch? i really want to get this car on the road this week if at all possible. thanks tim c. Link to comment Share on other sites More sharing options...
Nug Posted November 19, 2004 Share Posted November 19, 2004 Ever get the wheel pulled off? It sounds like the switch is bad. If you rent or borrow a puller, keep it long enough to yank the wheel off of the donor car at the junkyard. Link to comment Share on other sites More sharing options...
subyrally Posted November 19, 2004 Author Share Posted November 19, 2004 well, i think that i found a benefit to going to lti. i managed to fix the switch last night, tested it tonight, works great. Link to comment Share on other sites More sharing options...
torxxx Posted November 19, 2004 Share Posted November 19, 2004 how complicated is it changing out the dimmer switch? Mine is doing the same thing. High and Low beams on Low setting and then highs on at the high setting. Link to comment Share on other sites More sharing options...
CHIM Posted November 19, 2004 Share Posted November 19, 2004 i used to have a bit of a switch problem as well, First year & a half the high beams wouldn't work, i hit hi and the headlights would go out completly, Tryed several times to get it fixed and gave up every time. In the process of wiring my KC daylighters i ran a wire from my battery thrue the firewall beind my fuse box and then up to my console to the switch. Not sure what i touched or did but after i tesded my kc's my high beams have worked ever since. Wish i knew what it did. Link to comment Share on other sites More sharing options...
subyrally Posted November 20, 2004 Author Share Posted November 20, 2004 well, the switch crapped out again. gunna go see if my friend's dad can take a look at it. but the rx is on the road now im happy Link to comment Share on other sites More sharing options...
