snowstormer Posted November 20, 2004 Share Posted November 20, 2004 well i guess i learned something new today the hard way. i thought all ea81 blocks were the same. i took a bad ea81 out of an 83 coupe, was going to throw in a ea81 from a 82 brat[i think]. coupe was an auto. brat block was a 4 speed. both blocks are stamped ea81. took off the flywheel to install the auto flex-plate... and the flex plate will not physically clear the block. upon closer inspection the block is physically different. so i am kinda stuck. anyone ever put a ea82 into an 83 2wd coupe? i have a couple of those motors laying around... the flexplate fits on those motors... Link to comment Share on other sites More sharing options...
archemitis Posted November 20, 2004 Share Posted November 20, 2004 83? the ea82 should go in like it was stock. just close on the disty and the frame rail. Link to comment Share on other sites More sharing options...
snowstormer Posted November 20, 2004 Author Share Posted November 20, 2004 hey archemtis- thanks for the reply. will a ea81 intake manifold bolt onto a ea 82 block??? Link to comment Share on other sites More sharing options...
Qman Posted November 20, 2004 Share Posted November 20, 2004 What you have is an auto vs. manual bellhousing. If you look at the back of the block you will see a bunch of bolt heads inside the bellhousing(about 8-10 I think). If you remove those bolts you can swap the bellhousing. Make sure to use some sealant when you put it back together or it will leak forever. Also use lock-tite(thread sealant) on the bolts. This will also prevent oil leaks as the front side of the crank flange is exposed to the oil journals. Good luck! Also note that you will need to use the distributor from the '83. In '82 they used an ignition amplifier(parts connected to the holddown bracket on the coil). Link to comment Share on other sites More sharing options...
CHIM Posted November 20, 2004 Share Posted November 20, 2004 hey archemtis- thanks for the reply. will a ea81 intake manifold bolt onto a ea 82 block??? Yes, the manifold do interchange Link to comment Share on other sites More sharing options...
snowstormer Posted November 20, 2004 Author Share Posted November 20, 2004 thanks to everyone for the replies! the board saves the day again! Link to comment Share on other sites More sharing options...
subiemech85 Posted November 21, 2004 Share Posted November 21, 2004 here is the carb and intake manifold swap I did http://www.ultimatesubaru.org/forum/showthread.php?t=24564 Link to comment Share on other sites More sharing options...
snowstormer Posted November 21, 2004 Author Share Posted November 21, 2004 swapped the bellhousing over per Qman. went great. i hope to drop the motor in tommorrow. thank you everyone for the replies. have a good one. Link to comment Share on other sites More sharing options...
