stevejoy5 Posted November 23, 2004 Share Posted November 23, 2004 my impreza is playing up most of the time it boosts to 14psi but occasionally it will only boost to 8psi has anyone any ideas cause it is annoying? Link to comment Share on other sites More sharing options...
RallyKeith Posted November 23, 2004 Share Posted November 23, 2004 stevejoy5 said: my impreza is playing up most of the time it boosts to 14psi but occasionally it will only boost to 8psi has anyone any ideas cause it is annoying? Some more information on your car would be helpful. Year, model designation (WRX, WRX RA, WRX STi....) Also, is it only when in a specific gear? Keith Link to comment Share on other sites More sharing options...
stevejoy5 Posted November 23, 2004 Author Share Posted November 23, 2004 RallyKeith said: Some more information on your car would be helpful. Year, model designation (WRX, WRX RA, WRX STi....) Also, is it only when in a specific gear? Keith its a wrx 1992 the problem exists threw out every gear the car is an import, i have had the coil packs changed, a regular full service. i am not sure what else i can tell you Link to comment Share on other sites More sharing options...
Setright Posted November 23, 2004 Share Posted November 23, 2004 Sounds like you need to have your wastegate examined. The gate itself is inside the turbo, but the valve controlling it is mounted across the outside of the turbo. A metal "bellow" with a rod going through it. Link to comment Share on other sites More sharing options...
RallyKeith Posted November 23, 2004 Share Posted November 23, 2004 I'm not familiar enough with that car, but what is the boost pressure supposed to be? In other words I'm not sure if it's overboosting sometimes, or under boosting sometimes. Either way it sounds like something with the wastegate control. Have you ever driven the car with the windows down while this happens? I'm wondering if maybe you have an intermittant exhaust leak before the turbo that would cause it not to build up enough boost. Just throwing things out there to think about. Keith Link to comment Share on other sites More sharing options...
