how do i lock the hatch
I have an 83 wagon and i cant get the rear lift hatch to lock the key will only turn to the right, which doesnt lock it. It wont turn to the left at all.I am just making sure that theres not another way to lock it before i start taking things apart. It doesnt have auto locks i dont know if thats an option on 83's.
Thanks David
Your key will only turn 90 degrees. I believe straight up and down is open and sideways is locked. Sorry, been a while since we had ours.
EDIT, I just realized what you were trying to say. Take the interior panel off of the hatch. Inside you will see the linkage and lock cylinder and such. Look for a rod that is laying down in the bottom of the hatch. You'll see where it connects into the cylinder.
if its like my 90 wagon then turning it to the right unlocks it and it should turn a ways to the left about 45 degrees from stright up and down that locks it, try and squirt some liquid graphite in it mine stuck for a long time but that stuff freed it up.
