Leg93 Posted November 24, 2004 Share Posted November 24, 2004 So I've got my 93 Sub Legacy all tuned up and ready to change the fuel filter, but the hoses won't budge. I changed it last year in a parking lot in under 10 minutes with no problems. I worked on this for over an hour last weekend and ended up with nothing but bloody knuckles. Clamps are off (obviously) but the hoses won't budge. I thought about heating them up to soften the rubber, but only long enough to envision the ball of flame that would ensue. Short of using a knife and just replacing them, does anyone have a suggestion? Link to comment Share on other sites More sharing options...
frag Posted November 24, 2004 Share Posted November 24, 2004 If old and brittle, i would replace them. If not, go at them with a pair of battery pliers: give the hose a rotational movement to get it unstuck and then pull at it. My best. Link to comment Share on other sites More sharing options...
avk Posted November 24, 2004 Share Posted November 24, 2004 You can also try pushing hose ends off the connectors with an open-end 8 mm wrench. Link to comment Share on other sites More sharing options...
mrtoyou7747 Posted November 25, 2004 Share Posted November 25, 2004 I had the same problem. Replace the two rubber lines - they are not very long. Also put some teflon grease on the filter nipples when reassembling and you will get them off the next time. Link to comment Share on other sites More sharing options...
crauch Posted November 25, 2004 Share Posted November 25, 2004 Replacing them is good advice. I removed mine with the same problem. I had a hell of a time getting the ruber fule line back on even after I cut off an inch of both of the lines. Link to comment Share on other sites More sharing options...
Setright Posted November 25, 2004 Share Posted November 25, 2004 Get new hoses, cut the old ones, and lube the pipes on the new filter before installation. And get some antiseptic on those knuckles! Link to comment Share on other sites More sharing options...
WAWalker Posted November 25, 2004 Share Posted November 25, 2004 Spray some WD-40 on them. Link to comment Share on other sites More sharing options...
vrg3 Posted November 25, 2004 Share Posted November 25, 2004 Yeah, I also think cutting and then replacing them is a good idea. Just drop by your local auto parts supply and get some 5/16" fuel injection hose. Make sure it's fuel injection hose and not plain old fuel line, unless you relish a carbeque. Also make sure you use fuel injection clamps, not regular hose clamps. Fuel injection clamps have steel liners so they don't bite into the hose. If the stock clamps are in good shape then they're fine to reuse. If you do want to preserve the hose you have for whatever reason, I suggest getting a pair of hose clamping pliers. They're plastic and have rounded jaws so they're easy on hoses. I have found them helpful when trying to remove fuel injection hose. Link to comment Share on other sites More sharing options...
Leg93 Posted November 29, 2004 Author Share Posted November 29, 2004 Yeah, I also think cutting and then replacing them is a good idea. Just drop by your local auto parts supply and get some 5/16" fuel injection hose. Make sure it's fuel injection hose and not plain old fuel line, unless you relish a carbeque. Also make sure you use fuel injection clamps, not regular hose clamps. Fuel injection clamps have steel liners so they don't bite into the hose. If the stock clamps are in good shape then they're fine to reuse. If you do want to preserve the hose you have for whatever reason, I suggest getting a pair of hose clamping pliers. They're plastic and have rounded jaws so they're easy on hoses. I have found them helpful when trying to remove fuel injection hose. Thanks everyone! I'll add the new hoses to my shopping list. Link to comment Share on other sites More sharing options...
gbrand Posted November 30, 2004 Share Posted November 30, 2004 heat-use heat gun or pour some boiling water on them. Will help loosen up and definitly lube the tubes before reassy. Just did mine last month. Link to comment Share on other sites More sharing options...
Leg93 Posted November 30, 2004 Author Share Posted November 30, 2004 heat-use heat gun or pour some boiling water on them. Will help loosen up and definitly lube the tubes before reassy. Just did mine last month. Ahhh....a heat gun as opposed to a plumbers propane torch. Much more subtle, yet still effective. Nice touch. Link to comment Share on other sites More sharing options...
