torxxx Posted August 28, 2006 Share Posted August 28, 2006 they make brass wire wheels that work just fine. the brass is softer than the steel wire wheels. I use my 18v dewalt on highspeed and havent had any problems. Hell I took off an old head gasket before and it didnt hurt the head so I say go to town with the wire wheel Quote Link to comment Share on other sites More sharing options...
nkx Posted September 9, 2006 Share Posted September 9, 2006 where should i put rtv? on both sides of the new wp gasket?? Quote Link to comment Share on other sites More sharing options...
Caboobaroo Posted September 10, 2006 Author Share Posted September 10, 2006 where should i put rtv? on both sides of the new wp gasket?? yup but make sure you only put a thin layer on it or else it'll seep into the coolant passages and make its way around the system. Bad juju... Quote Link to comment Share on other sites More sharing options...
bec4bec Posted January 9, 2015 Share Posted January 9, 2015 Make sure to use a genuine Subaru o-ring on the water outlet to radiator( the metal pipe pushed into pump). I used the one that came with an aftermarket pump and it leaked until I put a factory one in. Quote Link to comment Share on other sites More sharing options...
Subaru_dude Posted January 9, 2015 Share Posted January 9, 2015 8 1/2 years. Impressive. Quote Link to comment Share on other sites More sharing options...
Subaru_dude Posted January 9, 2015 Share Posted January 9, 2015 8 1/2 years. Impressive. Oops, I mean over 10 years. Was counting from my post in 2006. Quote Link to comment Share on other sites More sharing options...
Caboobaroo Posted January 10, 2015 Author Share Posted January 10, 2015 When I saw this thread pop up, it made me laugh to go back through and read it. 1 Quote Link to comment Share on other sites More sharing options...
Crazyeights Posted January 10, 2015 Share Posted January 10, 2015 When I saw this thread pop up, it made me laugh to go back through and read it. After all these years it is still pretty relavant too. I am still working on these things at times, and they still run great! Quote Link to comment Share on other sites More sharing options...
DaveT Posted January 10, 2015 Share Posted January 10, 2015 I don't think I have ever put in an Oem o ring on the water pump, and I have not had trouble. I do make sure the pump surface is good, and the steel tube groove is clean. On some, I did use a small amount of rtv to seal the ring to the groove, as it was not in rhe best shape. More recently, I have been using a little bit of plumber's silicon grease on coolant hoses and o rings. Let's the move a bit and seal up, also, the hoses are not stuck on when I have to remove them. 1 Quote Link to comment Share on other sites More sharing options...
Crazyeights Posted January 10, 2015 Share Posted January 10, 2015 (edited) +1 About not needing a factory o-ring if the tube is good. I have never ordered one. I have used the factory metal gaskets though, if this is the right EA for those. Edited January 10, 2015 by Crazyeights Quote Link to comment Share on other sites More sharing options...
DaveT Posted January 11, 2015 Share Posted January 11, 2015 EA82 water pump uses a paper gasket. Quote Link to comment Share on other sites More sharing options...
Caboobaroo Posted January 11, 2015 Author Share Posted January 11, 2015 I found that I had to use an OEM o-ring on my XT6 as all the aftermarket versions I found were not quite as thick as the OEM one. Had two of them start leaking after 10,000 miles before I fitted the OEM o-ring. Quote Link to comment Share on other sites More sharing options...
MilesFox Posted January 11, 2015 Share Posted January 11, 2015 (edited) "" Edited January 11, 2015 by MilesFox Quote Link to comment Share on other sites More sharing options...
MilesFox Posted January 11, 2015 Share Posted January 11, 2015 For the sake of archive since search still brings this topic 1 Quote Link to comment Share on other sites More sharing options...
