Security System Extended Range
I have an 01 Forester, and I have contests with the kids on how far we can be away from it and still get it to unlock/honk.
Our Forester will work several hundred feet away. Enough that the people next to it have no idea why it just honked?
Are your batteries good?
You should have better range?
Glenn
82 SubaruHummer
01 Forester
Since you are still under warranty probably youmay want to let the dealer look at this. You should have more range than that I would think. You may have a bad transmitter and replacing the battery would be a good first step to see if that is bad. Do you have another fob you can compare the working range with?
