RavenTBK Posted November 30, 2004 Share Posted November 30, 2004 On the radiator, passenger side, below the thermoswitch.. It looked to have a flathead threaded slug in it. I say "looked" as I promptly attacked it with the screwdriver to snug it up when I found it leaking, I found it was made of plastic that was brittle as all hell. So I say it in past tense as its not slotted no more. Anywho.. what the heck is it, and what route should I take to cure the leak that appears to be eminating from this point? Link to comment Share on other sites More sharing options...
calebz Posted November 30, 2004 Share Posted November 30, 2004 Probably the drain cock for the radiator Link to comment Share on other sites More sharing options...
WJM Posted November 30, 2004 Share Posted November 30, 2004 calebz said: Probably the drain cock for the radiator Yep. As usual, calebz is on top of it. Link to comment Share on other sites More sharing options...
RavenTBK Posted November 30, 2004 Author Share Posted November 30, 2004 I thought the drain cock would've been further down.. *shrug* So.. since it was leaking, and now I've obviously FUBARed it.. is there any easy way to replace it or similar sized bolt I can put in its place? Is it actually threaded? Link to comment Share on other sites More sharing options...
carfreak85 Posted December 1, 2004 Share Posted December 1, 2004 Yes it is actually threaded. I just saw a draincock on ebay a little while ago. Don't think its there anymore. Link to comment Share on other sites More sharing options...
subiemech85 Posted December 1, 2004 Share Posted December 1, 2004 HELP section of auto parts strore, or radiator shop unscrew to drain and remove it is definately threaded drian cock replace to cure the leak it is supposed to have a tab to hold as you screw the thermoswitch is for the fan ground to turn on Link to comment Share on other sites More sharing options...
idosubaru Posted December 1, 2004 Share Posted December 1, 2004 i wasn't able to locate a replacement draincock at the standard auto parts retailers for the XT6. if you experience the same problem i'd just get someone to send you a used one. check with local radiator shops, seems they'd have these things lying around or deal with this. there should be plenty of old rusty radiators out there with perfectly good draincocks that someone would part with. it looks like the old drain cock is sheared off in the picture, is that the case? i temporarily used what was left of my old drain cock with some sealant all around the threads and it worked fine until someone mailed me one. as mentioned, it's threaded. if you can take the threaded part in, match the threads with something and use some sealant around the threads and you should be good to go. i'd make sure you get whatever you put in there to seat securely if it's not the standard drain cock, to prevent it from vibrating out. it will back out if it's not secure. Link to comment Share on other sites More sharing options...
moosens Posted December 1, 2004 Share Posted December 1, 2004 Raven,if you need a cock I have one. Be sure to pull yours out first. Then you can insert the one I have. OK,that was all funny,but I really do have a drain cock if you need one. Cheers. Link to comment Share on other sites More sharing options...
Bucky92 Posted December 1, 2004 Share Posted December 1, 2004 moosens said: Raven,if you need a cock I have one. Be sure to pull yours out first. Then you can insert the one I have. OK,that was all funny,but I really do have a drain cock if you need one. Cheers. Well..my mind went RIGHT to the gutter on this one....geesh its been a long time. Link to comment Share on other sites More sharing options...
XSNRG Posted December 1, 2004 Share Posted December 1, 2004 moosens said: Raven,if you need a cock I have one. Be sure to pull yours out first. Then you can insert the one I have. OK,that was all funny,but I really do have a drain cock if you need one. Cheers. Jeez Moosens, your just a little too eager to please! Link to comment Share on other sites More sharing options...
RavenTBK Posted December 1, 2004 Author Share Posted December 1, 2004 Bucky92 said: Well..my mind went RIGHT to the gutter on this one....geesh its been a long time.Same here.. I just about fell off the bed when I read that. Link to comment Share on other sites More sharing options...
RavenTBK Posted December 1, 2004 Author Share Posted December 1, 2004 Well, since its stripped all to hell, I'm going to pull the radiator tomorrow and knock the lil plastic bugger out with a punch.. well, knock it in and then flush it out. Should I actually search for a replacement drain cock in the Help! sections or will a bolt or somethin thread down into there. I'm more of a lower hose guy when it comes to draining.. so I'll never need the drain hole. What yall think? Link to comment Share on other sites More sharing options...
ShawnW Posted December 1, 2004 Share Posted December 1, 2004 I think you should take a dremel or engraver or something and make a notch in the remaining plastic so you can turn it with a screwdriver. Punching it into the radiator isn't the best idea. Link to comment Share on other sites More sharing options...
GLCraig Posted December 1, 2004 Share Posted December 1, 2004 Instead of carving the plug, take a flat screwdriver and heat the tip for a few minutes with a propane torch. Then press it into the plug and let it cool, it should turn pretty easily. Oh you don't need to get the screwdriver glowing, just a couple of minutes under the torch should be enough. Link to comment Share on other sites More sharing options...
subiemech85 Posted December 1, 2004 Share Posted December 1, 2004 a bolt won't work it's tapered and designed to seal properly without additional sealer http://www.motormitedormancatalog.com/item.wws?sku=61114&mfr=MOTORMITE&cookieID=1E31DBFG61E31DBLRL&clientid=motormitedorman&clientid=motormitedorman or http://www.motormitedormancatalog.com/item.wws?sku=61116&mfr=MOTORMITE&cookieID=1E31DBFG61E31DBLRL&clientid=motormitedorman&clientid=motormitedorman or http://www.motormitedormancatalog.com/item.wws?sku=61118&mfr=MOTORMITE&cookieID=1E31DBFG61E31DBLRL&clientid=motormitedorman&clientid=motormitedorman or http://www.motormitedormancatalog.com/item.wws?sku=61123&mfr=MOTORMITE&cookieID=1E31DBFG61E31DBLRL&clientid=motormitedorman&clientid=motormitedorman or http://www.motormitedormancatalog.com/item.wws?sku=61141&mfr=MOTORMITE&cookieID=1E31DBFG61E31DBLRL&clientid=motormitedorman&clientid=motormitedorman now all you need to do is find a place that has one, oriellyauto.com good luck! Link to comment Share on other sites More sharing options...
moosens Posted December 1, 2004 Share Posted December 1, 2004 EXACTLY,what Graig said. Heat the driver blade,insert,let cool,turn out,done. And then you'll need my which you can't find in any store at any price.Don't i wish. Most of us 70's owners have those around.I've got at least one complete radiator in excellent shape and another in very good condition.Good to boil them out at the age they're at.Go for the new cock plug and clean up the thermo sensor with some 0000 steel wool.Clean up the grounding point.Good for another 5 years with a good core. Cheers. Link to comment Share on other sites More sharing options...
Mudboat Posted December 1, 2004 Share Posted December 1, 2004 A 1.25 thread pitch is quite common on metric bolts, which is what the drain cocks should have. Get a bolt with that pitch that fits the hole, wrap it with teflon tape and screw it in and go... Link to comment Share on other sites More sharing options...
All_talk Posted December 1, 2004 Share Posted December 1, 2004 subiemech85 said: a bolt won't work it's tapered and designed to seal properly without additional sealer Nope, not tapered. Straight thread with a land for the O-ring to seal on. A standard metric bolt with some teflon tape will work just fine. If you dont believe me I can show you the broken one laying on my bench and the bolt in the radiator of my RX. :-p Good advice on the hot screwdriver trick, you really dont want that chunk of plastic floatin around in there. Gary Link to comment Share on other sites More sharing options...
88rxsedan Posted December 1, 2004 Share Posted December 1, 2004 All_talk said: you really dont want that chunk of plastic floatin around in there. why not, it could theoretically melt and seal a blown headgasket Link to comment Share on other sites More sharing options...
NorthWet Posted December 2, 2004 Share Posted December 2, 2004 IIRC, 12mm 1.25 pitch (at least on mine). Was thinking about putting a REAL drain on mine so that I could drain coolant into a pan instead of watering my underpans and burning my hands. Link to comment Share on other sites More sharing options...
DerFahrer Posted December 2, 2004 Share Posted December 2, 2004 It is completely impossible for a thread about a drain cock to steer completely clear of at least one innuendo Link to comment Share on other sites More sharing options...
subiemech85 Posted December 2, 2004 Share Posted December 2, 2004 subyluvr2212 said: It is completely impossible for a thread about a drain cock to steer completely clear of at least one innuendo yes, my cock dribbles :-p Link to comment Share on other sites More sharing options...
All_talk Posted December 2, 2004 Share Posted December 2, 2004 NorthWet said: IIRC, 12mm 1.25 pitch (at least on mine). Was thinking about putting a REAL drain on mine so that I could drain coolant into a pan instead of watering my underpans and burning my hands.My wagon has this type, short hose attches to the nipple, works pretty good. Gary Link to comment Share on other sites More sharing options...
NorthWet Posted December 2, 2004 Share Posted December 2, 2004 All_talk said: My wagon has this type, short hose attches to the nipple, works pretty good. Gary One of mine is kind of like that; looked around (sort of) for ones like it. Any idea where to get one like yours? Please don't say dealer, as I have problems getting parts from them when I know what VIN and have the part in hand. Link to comment Share on other sites More sharing options...
subiemech85 Posted December 2, 2004 Share Posted December 2, 2004 that is one of the links I posted, motormite, found in parts stores "HELP" section Link to comment Share on other sites More sharing options...
