ea81 heat ?
it being a brat with no ac, the recirc puts the air where I need it, helps to keep the windows clear too
the 195 thermostat, gasket, coolant heater and drain plug are on the list
napa had a special, buy a thermostat, get a free thermostat gasket
would the 180 thermostat be causing the trouble
it seems to warm up just fine but when I go down the road, it drops
Is your radiator fan kicking on?
Is your coolant low?
Is there a sale on thermostats?:rolleyes:
Got to be a thermo. If not it's a real cheap way to start trouble shooting the problem.
My Trooper gives cooler air (driving) when the coolant gets low....
My .02
Glenn
82 SubaruHummer
01 Forester
Subaru Heaters Rock!
that's what my dad's did when the t-stat stuck open. I had put in one of the safe-t-stats. his thermoswitch failed, and got hot, and it forced the t-stat to stick open. my mom kept complaining about being cold :) it would get nice and toasty sitting there warming up, but then drop down to the bottom of the guage when on the highway.
the only reason you're able to maintain 1/4 is because of the cardboard you put in.....
change thermostat to 195*
install coolant heater
the radiator drian cock was broke, amazingly it held :banana:
test drive 120* air out ac vent
temp guage stayed at 1/2
the old thermostat is good, so is the new one, I boiled them
the air sitll seems too cool :banghead:
will others please report the temps?? that would be helpful
I put a 205 thermostat in my brat the night I got it. It gets good heat (cant fun the heater on high for more then 5 or 10 min) at 0 F. Temp on the needle stays at about halfway up the gauge.
The parts store said they didnt stock a sooby 205 thermo, so I asked for a 54mm 205 degree chevy thermo and they had one.. funny how much carquest sucks... thermo works great
:lol: maybe there's too many drafts from the missing metal :grin:
