Auto trans question
Ok...if a automatic transmission, 1981 3AT, goes from 1st -3rd, under "normal" acceleration, is it the vacumn? If you floor it...it shifts OK thru 1,2,3. Seems to be OK when it's cold too. You can manually put it in 2nd without a problem. No other problems with the trans. 60K
(Paul...this is not my 78 automatic!)
I think that the only steel driven gear is from the turbo, but could be wrong. If the gear is not damaged, don't worry about it.
But I would disassemble and properly rework the governor valving. I am beginning to think that this is where the problem starts, and that the coring is a symptom of the out of balance stuck valve.
