Changing shift light on 96 Legacy
I wish my memory was better...I just did this on my 95 a couple of weeks ago. I ended up removing all the black trim that you see from between the radio area to the armrest console. If you lift up the armrest compartment, you'll see a screw which needs to be undone. Then there were a couple of spots where the trim popped off, either the sides, or the top near the front.
Once that trim is off, there were a couple more screws which needed to be removed around the shifter (be careful not to drop any of these screws!). Then I was able to move the trim around the shifter up high enough, that I could get my fingers underneath and blindly unscrew the mount for the lamp bulb. Take that bulb in to your local auto store and get one that looks similar. If I remember correctly, I went with a 94 or 95 bulb, but that was actually a little brighter than the one before. I think a 74 was the one that I decided I should have gotten.
