pwoens Posted December 8, 2004 Share Posted December 8, 2004 Whats the connection for bigger radiators?? Looking for the ea82t 1988 wagon. Want atleast a double?? 1stsoob doesnt carry them or have access?? Any other ideas?? Thanks Link to comment Share on other sites More sharing options...
monstaru Posted December 8, 2004 Share Posted December 8, 2004 ask your friends in town and have them direct you to a place off of freya!!!!! drew got a double row made for his wagon on freya, across from napa,right behind ram engine. on a side note the xl has spark!!!! i am stoked. Link to comment Share on other sites More sharing options...
pwoens Posted December 8, 2004 Author Share Posted December 8, 2004 monstaru said: ask your friends I have friends??? hahahhaha How bout I pay you to find one at the yard Got your 9 bucks too Link to comment Share on other sites More sharing options...
monstaru Posted December 8, 2004 Share Posted December 8, 2004 i can find anything,but my price for you would be astronomical:brow: grinding the caliper, how long did we talk about that yesterday....geez....what an easy fix...you got lucky.i will be at the yard in about an hour,i ahve to cut that glasspack off..... Link to comment Share on other sites More sharing options...
Marck Posted December 8, 2004 Share Posted December 8, 2004 Here is a link to the 2 row that I bought, although I phone ordered mine. I think it is made by CSF. http://www.radiatorconnection.com/auto/HiPerformance/Subaru/sc1.htm Link to comment Share on other sites More sharing options...
WJM Posted December 8, 2004 Share Posted December 8, 2004 *subcribe* Marck: How well does it work/look/fit? Hows the contruction on it? Link to comment Share on other sites More sharing options...
Marck Posted December 8, 2004 Share Posted December 8, 2004 WJM said: *subcribe* Marck: How well does it work/look/fit? Hows the contruction on it? I didn't notice much improvement over the old radiator, because I replaced a two row with another two row. It looks like OEM. It is constructed of brass and comes with a lifetime warrantee from manufacturer. It is direct fit and has the ATF hookups for Autos, but on I think the dealer installed A/C subarus the mechanical fan gets really close to the radiator which only makes it a pain to install or remove the radiator. I had to force the engine back a little bit to fit the fan on the water pump studs. Probably could be made easier by using bolts instead of studs on the water pump pulley. Link to comment Share on other sites More sharing options...
WJM Posted December 8, 2004 Share Posted December 8, 2004 The 2 row one I have in the wagon is like that...but it was not THAT close. Link to comment Share on other sites More sharing options...
Marck Posted December 8, 2004 Share Posted December 8, 2004 WJM said: The 2 row one I have in the wagon is like that...but it was not THAT close. You might have factory installed A/C. Link to comment Share on other sites More sharing options...
WJM Posted December 8, 2004 Share Posted December 8, 2004 I had it in an RX with dealer AC (tall pump)....and it was similar clearance. The wagon has the short pump. Link to comment Share on other sites More sharing options...
archemitis Posted December 8, 2004 Share Posted December 8, 2004 you can fit a legacy radiator in there with a few modifications, then your open to alot more aftermarket ones too. it required adapters... but its bigger =] Link to comment Share on other sites More sharing options...
baccaruda Posted December 8, 2004 Share Posted December 8, 2004 Performance Radiator across from the Kmart on E. Sprague has them sometimes. They carry various brands. I bought a double row Modine for my brat for $110 I think. Also try A-Star Distributing on N. Market. They do large collision repair items and include radiators. Their selection varies as well. Link to comment Share on other sites More sharing options...
Caboobaroo Posted December 9, 2004 Share Posted December 9, 2004 lookin for the same thing man! I'm lookg for a 3-row for my RX. Been thinkin about a Legacy radiator since there's a few here in the yards as well.....If you can find a 2-row, see about a 3-row as well! Link to comment Share on other sites More sharing options...
tizzle Posted December 25, 2004 Share Posted December 25, 2004 bump, anymore info on adapting a legacy radiator, archemitis? Link to comment Share on other sites More sharing options...
JonOfScio Posted December 25, 2004 Share Posted December 25, 2004 with the older vehicles, I don't see why you couldn't fit a legacy radiator, they don't look much bigger than the EA81/EA82 radiators, and there's tons of room in front of those motors, but I don't know about in the EA82 cars. mounting would be easy of course, just make new mount spots in your radiator support beam. I guess the issue would be clearance and space. Link to comment Share on other sites More sharing options...
Myxalplyx Posted December 26, 2004 Share Posted December 26, 2004 Marck said: I didn't notice much improvement over the old radiator, because I replaced a two row with another two row. It looks like OEM. It is constructed of brass and comes with a lifetime warrantee from manufacturer. It is direct fit and has the ATF hookups for Autos, but on I think the dealer installed A/C subarus the mechanical fan gets really close to the radiator which only makes it a pain to install or remove the radiator. I had to force the engine back a little bit to fit the fan on the water pump studs. Probably could be made easier by using bolts instead of studs on the water pump pulley. Marck said: Here is a link to the 2 row that I bought, although I phone ordered mine. I think it is made by CSF. http://www.radiatorconnection.com/auto/HiPerformance/Subaru/sc1.htm This is good to know. Must keep this manufacturer in mind if I am looking for a new radiator. Thanks! Radiator - Aftermarket - 2 core - 3 core - Racing Link to comment Share on other sites More sharing options...
subynut Posted December 26, 2004 Share Posted December 26, 2004 Ah HA! THAT's why my sister's wagon has no clearance between the clutch fan and the radiator. When I replaced the t-belts, I poked a hole in the radiator trying to get the clutchfan off. Now, she has an electric fan there and a patched radiator. Link to comment Share on other sites More sharing options...
Myxalplyx Posted January 10, 2005 Share Posted January 10, 2005 *Bump of semi-old thread* My radiator replacement is coming sooner than I expected. Laying under the car removing certain items, I noticed that my radiator is rusted/corroded. You can push lightly on it with your pinky finger and it just seems to turn to dust with various pieces falling to the ground. Not good! My temperature gauge holds in the middle but I'm not one to wait for things to happen, especially when I see something going wrong with it. I'm trying to do as much preventive maintenance as possible before going much further with upgrades. I'm looking at thepartsbin.com and I noticed two radiators for the RX turbo. One is for $101.80 (Radiator Metal tank, G1000-49017), while the other is for $136.96 (Radiator Heavy duty metal tank, G1000-48574). There is no mention of the two being single, double or anthing else row. Can anyone recommend which one I should choose and why? I want to assume the higher priced one is better but sometimes that simply isn't the case. Someone here may have some experience purchasing either one of these radiators. Thanks! Link to comment Share on other sites More sharing options...
Caboobaroo Posted January 10, 2005 Share Posted January 10, 2005 yeah me needy one too... mine has a spot where the mechanical fan smacked into it when the waterpump gave way in its previous lifetime.... Link to comment Share on other sites More sharing options...
FirstSubaruGLwagon Posted July 28, 2005 Share Posted July 28, 2005 I know this is going to sound stupid,, but thats the way i normally sound,,,, But,, I recall veagly someone saying something about putting a Jeep cherokee radiator in a subee.. Anyone know anything aboout that? Link to comment Share on other sites More sharing options...
