aldeveron Posted December 8, 2004 Share Posted December 8, 2004 How does the DR work? I understand transaxles (front and rear drive) and I understand the typical 4WD drive setup (stick a 2-speed transfer case in between transmission and rear end). The subie dual range I do not understand. Is the dual ranging all done within the transaxle housing or is there some other magic going on. Thanks, JM Link to comment Share on other sites More sharing options...
MorganM Posted December 8, 2004 Share Posted December 8, 2004 There is a transfercase it's just bolted onto the rear of the tranny and looks like all one unit. As for specfic details on how it precisly works? I'll let the experts handel that Link to comment Share on other sites More sharing options...
NorthWet Posted December 8, 2004 Share Posted December 8, 2004 IIRC, the 2-speed gear set is on the input shaft inside of the final-drive case on the front of the transaxle. Nothing fancy. Link to comment Share on other sites More sharing options...
ccrinc Posted December 9, 2004 Share Posted December 9, 2004 There are actually two sets of gears inside the dual range tranny: one for "normal" and one for "low". I've seen that job and I don't want it!! When you shift into 4x low, you actually engage the 2nd gear set, I do believe. On the other hand, I'm not the total tranny guru, and I'm going on memory... Emily http://www.ccrengines.com Link to comment Share on other sites More sharing options...
Ross Posted December 9, 2004 Share Posted December 9, 2004 There are actually two sets of gears inside the dual range tranny: one for "normal" and one for "low". I've seen that job and I don't want it!! When you shift into 4x low, you actually engage the 2nd gear set, I do believe. On the other hand, I'm not the total tranny guru, and I'm going on memory... Not that i've ever taken a d/r apart, but this sounds a little odd to me..... I would think that there would be a 2 speed g/box attached to the output of the main g/box. Link to comment Share on other sites More sharing options...
NorthWet Posted December 9, 2004 Share Posted December 9, 2004 The FSM for the d/r 5 speed shows the hi/lo gearing above the diff in the front housing; this is also where the hi/lo selector linkage attaches. Far easier to do on the input shaft than the output, as the torque it has to handle is limited to engine's, not multiplied by gearing. Link to comment Share on other sites More sharing options...
Numbchux Posted December 9, 2004 Share Posted December 9, 2004 Far easier to do on the input shaft than the output, as the torque it has to handle is limited to engine's, not multiplied by gearing. AND, if you were to try to do it after, you'd have to have to 2-speed gearboxes, or run a driveshaft withing the transaxle from said gearbox to the front diff. So... theoretically (though I can't see a reason you'd do this) you could disable the 4WD part, and still have D/R FWD. huh.... Link to comment Share on other sites More sharing options...
All_talk Posted December 9, 2004 Share Posted December 9, 2004 Yep, on the input shaft. Check this thread for the "inside" scoop. :-p http://www.ultimatesubaru.org/forum/showthread.php?t=15410&highlight=inside+tranny Gary Link to comment Share on other sites More sharing options...
Sweet82 Posted December 9, 2004 Share Posted December 9, 2004 So....... Which gears are regular and which are low range? They kinda all look alike to me It would be cool to know which gears do what? Anyone capable of labeling those parts? Trannys are over my head! Glenn 82 SubaruHummer 01 Forester Link to comment Share on other sites More sharing options...
All_talk Posted December 9, 2004 Share Posted December 9, 2004 Check the linked thread... somebody else had the sane thought. Gary Link to comment Share on other sites More sharing options...
