Announcements
Fuel Cut Solution
  • Replies 52
  • Created
  • Last Reply
Top Posters In This Topic
"The way most ECU overboost protection works is by monitoring manifold pressure through a pressure sensor. When the readings go too high, the ECU stops pulsing the fuel injectors. On the Legacy Turbo, this happens when the ECU reads a pressure above approximately 28 psia for longer than approximately 3 seconds."
since we dont have a factory MAP sensor, we'd be better off going with MS, right?
