WRX Clutch discovery!
WJM
The application I see here is that clutchmasters makes a clutch kit (new gen) that is only SLIGHTLY stiffer than stock and held up to 305Hp on my old 2.5RS for almost 100k miles. The disk is more of a factor than the PP in that kit. That disk could be used and provide substantial improvement even if the stock PP is used. Although, since I am reffering to the Gen1 RS it is a push type, you could always redrill/peg that PP to work with the flywheel if needed.
this whole clutch thing had me thinkin and looking... i was trying to track down the exedy clutch for the ea82 chassis ( good clutch imo) and found that it lists 200mm for 2wd models and 225 for 4wd models.. I havent had a problem using 2wd to 4wd or vice versa when throwing clutches around in subarus... what gives?
rllywgn
as long as you use all the 2wd stuff with 2wd stuff and 4wd stuff with 4wd stuff...it doesnt matter.
2wd and 4wd input shafts are different splines, clutch discs different diameters, plates and flywheels accordingly.
