mcbrat Posted December 12, 2004 Share Posted December 12, 2004 82 Brat. Dual Batteries with solenoid between them. Xt6 Alternator. when I first start it up, it will not charge. as soon as I take it over 3500 RPM's then it will charge,even when RPM's go lower... bad diodes, or need a new wire from alt to battery? Link to comment Share on other sites More sharing options...
NorthWet Posted December 12, 2004 Share Posted December 12, 2004 82 Brat. Dual Batteries with solenoid between them. Xt6 Alternator. when I first start it up, it will not charge. as soon as I take it over 3500 RPM's then it will charge,even when RPM's go lower... bad diodes, or need a new wire from alt to battery? Funny that you should ask... my alt (non-XT6) started doing something similar a couple of days ago. I haven't dug too deep into yet, as week-long deluge here makes it inconvenient. Anyway, first thought was worn brushes, but the voltage stays slightly too high on mine, so I am beginning to think VR. I'll swap it out and have it tested, hopefully tomorrow. Link to comment Share on other sites More sharing options...
ShawnW Posted December 12, 2004 Share Posted December 12, 2004 Id guess moisture or oil is getting in the brushes and that spinning the alt at that RPM is giving them a quick cleaning so they start working. Link to comment Share on other sites More sharing options...
Vanislru Posted December 12, 2004 Share Posted December 12, 2004 Get a can of Contact cleaner, electrical wholesaler should be the cheapest, and give the alt a solid blasting around the brushes. Should remove any of the carbon and crap. Link to comment Share on other sites More sharing options...
Cougar Posted December 12, 2004 Share Posted December 12, 2004 I very much doubt that the diodes are causing this but it could be the brushes as was mentioned or also the regulator, rotor, or stator. I would suspect the regulator the most. At any rate, it seems you are going to need another alternator unless you pin it down. If you have more than 80k miles on the unit then I would replace it with a remanufactured unit. Link to comment Share on other sites More sharing options...
NorthWet Posted December 12, 2004 Share Posted December 12, 2004 Almost a hijack: Anybody have any luck disassembling the GL-series alternators? I think that I tried once, and have a few partially torn-down ones that others have tried and failed on. I used to replace brushes all the time on other styles (Datsun, Mistu, GM), so would be nice to try that on soobs. ("all the time", 'cuz I have around 500k miles of road behind me...) End of almost hijack. Link to comment Share on other sites More sharing options...
naru Posted December 12, 2004 Share Posted December 12, 2004 Almost a hijack: Anybody have any luck disassembling the GL-series alternators? I think that I tried once, and have a few partially torn-down ones that others have tried and failed on. I used to replace brushes all the time on other styles (Datsun, Mistu, GM), so would be nice to try that on soobs. ("all the time", 'cuz I have around 500k miles of road behind me...) End of almost hijack. Yes,Brushes are a piece of cake.Requires a soldering iron. Regulator a little trickier,but not much. Link to comment Share on other sites More sharing options...
NorthWet Posted December 12, 2004 Share Posted December 12, 2004 Yes,Brushes are a piece of cake.Requires a soldering iron. Regulator a little trickier,but not much. OK, not an issue with soldering, as I have ElecTech experience. But my problem is separating the unit to get at them. On all other alts that I have worked on, the back case came loose from the stator/rotor/front housing pretty easily. IIRC, the one time I tried that with the soob it frustrated me. Any hints? Or is my memory flakey? Link to comment Share on other sites More sharing options...
naru Posted December 12, 2004 Share Posted December 12, 2004 OK, not an issue with soldering, as I have ElecTech experience. But my problem is separating the unit to get at them. On all other alts that I have worked on, the back case came loose from the stator/rotor/front housing pretty easily. IIRC, the one time I tried that with the soob it frustrated me. Any hints? Or is my memory flakey? Been a while since I did it so I had a quick look at the FSM to be sure. Just remove the through bolts and tap it apart.EA-81,but I`m sure they are all the same. Link to comment Share on other sites More sharing options...
torxxx Posted December 13, 2004 Share Posted December 13, 2004 EA81 and EA82 alts are the same after a certain year. I think its 1984 and newer have the internal voltage regulator. I used a alt from a 85 brat (on my 86 ea82) and it works great. Taking them apart is easy. just take out the 4 phillips head screws on the outside and tap the mounting ears apart. When you are putting it back together, you have to push a piece of bailing wire through the back of the VR half of the alt. it holds the contacts in that push onto the brushes. I've rebuilt about 10 of them. only two didnt work, and that was because I had two different size alternators. Link to comment Share on other sites More sharing options...
subaru_styles Posted December 13, 2004 Share Posted December 13, 2004 hey Mcbrat, when I bought my coupe it was doing the exact same thing.....1 week later the alternator took a crap on me. Link to comment Share on other sites More sharing options...
NorthWet Posted December 13, 2004 Share Posted December 13, 2004 Changed out my alternator today. As expected, the voltage came up as it should without revving. Plus, the voltage stayed where it should, about 1.5 volts lower than where it has been recently. McBrat, good luck. Definitely change out that alt before it leaves you in a world of hurt. Link to comment Share on other sites More sharing options...
All_talk Posted December 13, 2004 Share Posted December 13, 2004 82 Brat. Dual Batteries with solenoid between them. Xt6 Alternator. when I first start it up, it will not charge. as soon as I take it over 3500 RPM's then it will charge,even when RPM's go lower... bad diodes, or need a new wire from alt to battery? Sounds like its not self-exciting, might be a problem with your dual battery system, did it work normaly with this system before? I had the same problem with a dual battery system in my '65 Pontiac, Just gave her a rev and lived with it for years. NorthWet, I've got a Subie alternator apart on the bench, you can stop and take a look next time your in E-burg if ya like. And while you're here you can check out my new shop toy... Its got lots of levers and cranks and turns bigger bits of metal into littler ones. Gary Link to comment Share on other sites More sharing options...
