EA81 & EA82 alt compatability...
you broke it already?
sorry just messin with ya.
you shure its the Alt.?
the battery is fairly new thats in it. It was a good used one I put in there not too long before my cousin picked it up. never messed with the alt. though.
Im sure you can find one or make somthing fit. if not let me know I may be able to find somthing for you if all else fails.
I just want to get the thing home. Then I'll worry about the rest. Im pretty sure was the alternator. The car started to stumble off idle, and after a block or so it would have no power past 4k, then past 3k unless I were to feather the throttle. Then i came to a light where my stereo stopped working and the car started to loose its idle. After the car died, I tried to restart it but the crank turned really slow, so I just used the remaining power for flashers and to turn the windows up.
I'll take one of these EA81 alts (from my 84 so internal regulators) and get the car home.
-Brian
When you get it home, charge the battery fully too.
-Brian
Took the Alt from my EA81 wagon and stuffed it in the RX. The battery had enough juice to start it up, and it ran and drove just fine after that. Im wondering if it was even the alt, im thinking it might have been the BAT wire. When i tried to remove that wire from the RX's alt, it was so brittle it just snapped. I put a new end on it, and tightened it to the EA81 alt and all is well.
-Brian
