Jeepman775 Posted December 15, 2004 Share Posted December 15, 2004 First of all if you are really serious about getting an FMIC you are going to need to take out you A/C. Then you can fit a huge one in. Anyway can anyone think of a slick easy way to do the IC plumbing on an FMIC, I am going to start with a small one as that is all I can afford at the moment. Plus I'd like to keep my spool time a few more weeks. Here is a pick of the one I one. My next one is going to be one with input output on opposite ends. Link to comment Share on other sites More sharing options...
archemitis Posted December 15, 2004 Share Posted December 15, 2004 First of all if you are really serious about getting an FMIC you are going to need to take out you A/C. Then you can fit a huge one in. Anyway can anyone think of a slick easy way to do the IC plumbing on an FMIC, I am going to start with a small one as that is all I can afford at the moment. Plus I'd like to keep my spool time a few more weeks. Here is a pick of the one I one. My next one is going to be one with input output on opposite ends. thats a ford probe/mazda intercooler, i always liked that one. use prebent exhaust tubing, and silicone, or rubber couplings. use around 1/78, since thats close to what the tubes were on the probe, and it'll keep your spool time quick. theres a recirc valve that you can plumb in, from the probe/mazda. Link to comment Share on other sites More sharing options...
bajavwnsoobnut Posted December 15, 2004 Share Posted December 15, 2004 well for when you go with the other IC just take a look at how this guy did his: http://www.boostcruising.com/forums/index.php?act=section§ionID=6&entryID=201 found it on yahoo while doing a search for images of RX's a short while back Link to comment Share on other sites More sharing options...
