changing the clutch
IMHO: DON'T pull the tranny out. It weighs a ton, and is very hard to bench press back into place. Pulling the engine is my favorite way, though others prefer to just separate the engine and tranny and move one or the other back a little to gain working space (I haven't tried this... yet :-\ ).
If you do pull the engine, and if you have A/C, don't disconnect/depressurize the system. Just unbolt A/C mount bracket and lay the compressor to the side and out of the way.
Not a hard job.
That's what a hefty floor jack is for. Just set it on the jack, roll it under the car, let the jack lift it into place.
Well, yes, given the right situation you can use the right equipment. But this requires that the car be significantly raised up in the air. My 10-ton floor jack and 6-ton stands wouldn't give me enough height to do this. Plus, you really need either a tranny jack or a device on the jack saddle to handle the tranny.
