gsrxrsx68 Posted December 16, 2004 Share Posted December 16, 2004 Questions on two techniques: 1. I read a post which suggested place the car in fifth gear, set the break and use a breaker bar to remove the crank pulley. Any thoughts? I started to do this and got to thinking about all the torque and stopped myself. Any chance of causing damage using this technique? 2. Someone posted they would remove the engine if they had to do the head gasket again so they could adjust the valves. If you have the head off is it possible to adjust the valves then? I guess I should run to the store and get a manual. Link to comment Share on other sites More sharing options...
Legacy777 Posted December 16, 2004 Share Posted December 16, 2004 what car? You won't damage anything. Your engine puts out more torque then what you can get on a torque wrench. If you have a newer subaru, most have hydraulic lifters and there's no adjustments that need to be done. Link to comment Share on other sites More sharing options...
gsrxrsx68 Posted December 16, 2004 Author Share Posted December 16, 2004 Thanks, Iforgot...it is a '97 obw Link to comment Share on other sites More sharing options...
ccrinc Posted December 16, 2004 Share Posted December 16, 2004 '97 Outback EJ25 DOHC = solid lifters. Emily http://www.ccrengines.com Link to comment Share on other sites More sharing options...
