My '95 Legacy wagon (200K+ miles) makes a clunking noise when I travel over "sharp" bumps. It would be most noticeable on, say, washboards on a dirt road. I did some looking/asking and I'm thinking it's a worn mounting/bearing plate on the strut(s). Is this common? Seems I've heard a similar noise in other cars with tons o' miles on them. Am I on the right track? Can I get these plates aftermarket or is it a dealer item?
Mike
Since you have to remove the strut from the car and the strut support (that's the part you're talking about) from the strut and spring (need a spring compressor if you do it yourself) to make that repair, I think you should replace the strut altogether if they have never been replaced. At 200 K They should need replacement in a short while if not right now.
You can get a reasonnable price for OEM struts and hardware at 1stSubaruparts. That's were I got mine when I replaced them this last summer.
Good luck!
Thanks, it is indeed the strut support/mount that I think is causing the noise. I agree that it makes sense to replace the struts at the same time. I just checked out '1stsubaruparts' and their website is incredibly well designed and intuitive, I'll be ordering from them. Thanks again.
Mike
Good luck!
