Roundeye Posted December 18, 2004 Share Posted December 18, 2004 I did a search and found nothing for my specific car. I plan to get a set of 15" 6 lug rims from a JY and drill them to fit my hubs. These will go on a NON-LIFTED, stock 1987 D/R Wagon. My questions are: 1. What rims (year/make/width) have the best back-spacing to put on my car? 2. What is the largest tire I can put under it without scrubing at maximum flex with the steering at full turn? Thanks in advance. Link to comment Share on other sites More sharing options...
monstaru Posted December 18, 2004 Share Posted December 18, 2004 i would suggest that you get 14 inch 6 lug rims.and drill your hubs, not the rims.you can acquire 14" 6-lugs off of mazda and nissan 4x4's.at the yard i have mounted the following rims on soobs-isuzu,nissan,chevy,mazda,gmc, and toyota.the mazda and nissan must be 4x4 in order to be 6 lug.out of the ones that i mounted the 14 inch rims were sporting 205/75/14 and 195/75/14,they turned well in the front and had enough backspacing to clear the struts.the 15" rims i mounted had varying tire sizes and had good backspacing as well.from what i understand.....most any rims that i mentioned still have less backspacing than your average pug.and alot of people run pugs.so, i would go to your local junkyard and find some that you like.find out the return policy and if you do not like the performance.switch 'em out.you will also need some extra hubs for studs and if you want to do it off of the car and then mount them. Link to comment Share on other sites More sharing options...
monstaru Posted December 18, 2004 Share Posted December 18, 2004 oh yeah,here is a link on how to drill your hubs outhttp://subarubrat.com/6lugconv.htm Link to comment Share on other sites More sharing options...
ezapar Posted December 18, 2004 Share Posted December 18, 2004 If you looked at the FAQ sticky in the Off Road Forum, you'd most likely find the answers you're looking for. . . Link to comment Share on other sites More sharing options...
MorganM Posted December 20, 2004 Share Posted December 20, 2004 http://www.ultimatesubaru.org/forum/showthread.php?t=25873 Link to comment Share on other sites More sharing options...
bushbasher Posted December 23, 2004 Share Posted December 23, 2004 6bolt 2wd datsuns are a good source, I think 2wd mazdas are 5 bolt however. I found a set of 8 spoke 14" rims with nearly the same offset as standard subaru rims. I ran my ea82 no lift with these rims and 26" tires with little trouble. Link to comment Share on other sites More sharing options...
monstaru Posted December 23, 2004 Share Posted December 23, 2004 oh yeah, and if you like the rims and they fit your style , tire preferance, just get a big ****ing hammer and pound away..... Link to comment Share on other sites More sharing options...
