N8NQU Posted December 21, 2004 Share Posted December 21, 2004 i have adjusted it al the way on the rod by the E-Brake and it still does not want hold the car,you can push the car and it moves just like it's no brake both front wheels move free,.the brake was working untill last weekend and it started acting up.thanks in advance,Bill http://www.ultimatesubaru.org/forum/newthread.php?do=newthread&f=2# Brick Wall Link to comment Share on other sites More sharing options...
Ross Posted December 21, 2004 Share Posted December 21, 2004 Is there any resistance when you pull up the handle? When you pull the handle, does the Splitter bar (where one cable turns into two, under the center console) rotate about the center pin? Both of these symptoms would indicate a broken cable/cable mount. Link to comment Share on other sites More sharing options...
86subaru Posted December 21, 2004 Share Posted December 21, 2004 i just got 86 3 door carb fwd manual ,136,000mi ,it needs a few things ,but over all for the price it was worth it , i think i'll put in a s/r or d/r which i have both , alittle rust , i am not sure how to post pics , Link to comment Share on other sites More sharing options...
N8NQU Posted December 21, 2004 Author Share Posted December 21, 2004 Is there any resistance when you pull up the handle? When you pull the handle, does the Splitter bar (where one cable turns into two, under the center console) rotate about the center pin? Both of these symptoms would indicate a broken cable/cable mount. no resistance it pull up a okay and the cable that goes to each front wheel moves but it does not grab the wheel.when the E-brake is on you can still rotate the front tires.i'll have to go look at splitter bar. Link to comment Share on other sites More sharing options...
N8NQU Posted December 21, 2004 Author Share Posted December 21, 2004 i just got 86 3 door carb fwd manual ,136,000mi ,it needs a few things ,but over all for the price it was worth it , i think i'll put in a s/r or d/r which i have both , alittle rust , i am not sure how to post pics , good score you will like the 3 door,i drive ours only the winter but i sure like the room that they have and the looks of them.i am going out to the garage to take a look at the E-brake again. Link to comment Share on other sites More sharing options...
N8NQU Posted December 22, 2004 Author Share Posted December 22, 2004 no resistance it pull up a okay and the cable that goes to each front wheel moves but it does not grab the wheel.when the E-brake is on you can still rotate the front tires.i'll have to go look at splitter bar. BUMP Link to comment Share on other sites More sharing options...
JWX Posted December 23, 2004 Share Posted December 23, 2004 are the arms on the caliper moving when you pull on the handle? Link to comment Share on other sites More sharing options...
N8NQU Posted December 23, 2004 Author Share Posted December 23, 2004 are the arms on the caliper moving when you pull on the handle? both arms move about the same distance,i had the wife pull on the E-brake and with the tires off i was looking at them move.it was working fine untill last saturday when i put theE- brake on and the car started moving.the E- brake grabs zero. Link to comment Share on other sites More sharing options...
stngllhm Posted December 23, 2004 Share Posted December 23, 2004 how worn are your front pads. i have noticed that the closer they get to worn out the more you have to pull up on the e-brake handle Link to comment Share on other sites More sharing options...
N8NQU Posted December 24, 2004 Author Share Posted December 24, 2004 how worn are your front pads. i have noticed that the closer they get to worn out the more you have to pull up on the e-brake handle brand new pads,only 2k miles on them. Link to comment Share on other sites More sharing options...
JWX Posted December 24, 2004 Share Posted December 24, 2004 have you checked them since it stopped working? Link to comment Share on other sites More sharing options...
MilesFox Posted December 24, 2004 Share Posted December 24, 2004 http://www.warpthree.com/milesfox/subaru/service/parkingbrake.htm are all the clips in place, especially the on eon the caliper end of the cable? Link to comment Share on other sites More sharing options...
N8NQU Posted December 24, 2004 Author Share Posted December 24, 2004 have you checked them since it stopped working? yes,the front brakes work fine. Link to comment Share on other sites More sharing options...
N8NQU Posted December 24, 2004 Author Share Posted December 24, 2004 http://www.warpthree.com/milesfox/subaru/service/parkingbrake.htm are all the clips in place, especially the on eon the caliper end of the cable? everything is hooked up and when the wife moves the E- brake they both move the same distance. Link to comment Share on other sites More sharing options...
N8NQU Posted December 26, 2004 Author Share Posted December 26, 2004 everything is hooked up and when the wife moves the E- brake they both move the same distance. Bump Link to comment Share on other sites More sharing options...
singletrack Posted December 27, 2004 Share Posted December 27, 2004 In the bicycle world we would call this "cable stretch" which is really housing compression. Back the p-brake adjuster out, and cinch up those cables at the caliper arm. Also, disconnect the cable all together and move the arm by hand [well, channel locks would be better] till it stops, see if you can turn the hub. If the brake works by hand, its definetly cable tension. That's my best guess anyway. Link to comment Share on other sites More sharing options...
