wcarey Posted December 21, 2004 Share Posted December 21, 2004 We just got our 2005 2.5i wagon on Saturday. My dog travels with me quite often and likes to sit in the front passenger seat. Even at only 30 lbs, she still triggers the fasten seatbelt warning chimes. I tried buckling the seatbelt behind her, but she still got tangled in it. I would like to be able to disable the passenger side seatbelt warning altogether (lights and chimes). The owner's manual is no help in this matter. Has anyone figured out how to do this? Link to comment Share on other sites More sharing options...
gbhrps Posted December 21, 2004 Share Posted December 21, 2004 Wcarey, I don't know for sure if this will work, but my limited electrical knowledge says it might. Obviously when you turn on the ignition, if the passenger seatbelt isn't buckled, the buzzer goes off. So there must be a switch inside the seat belt receiver that in disconnected when the belt is buckled up properly. So, follow the seat belt receiver down along the centre (Canadian spelling) console until you find the wiring harness where it disconnects. Unplug the wiring harness connector and see what happens. If no buzzer sounds when you turn on the ignition, great. If it does, try joining the contacts inside the harness with a jumper wire and try again. Maybe someone else has a different handle on this one. Good luck! Link to comment Share on other sites More sharing options...
cookie Posted December 21, 2004 Share Posted December 21, 2004 On a BMW if you turn the key on with anything in that circuit disconnected it triggers the airbag light. This can only be turned off by buying the SRS specific light resetting tool or going to the dealer. You might be better off fastening the belt and putting a cheap lower cover over the belt system, or rationally putting the dog in the back. Link to comment Share on other sites More sharing options...
charlierh2 Posted December 22, 2004 Share Posted December 22, 2004 http://legacygt.com/forums/showthread.php?t=2023&page=5&pp=10&highlight=buzzer look thru here this seems to be what works (1/2 wat down the page) but look through there might be more later on Link to comment Share on other sites More sharing options...
brus brother Posted December 22, 2004 Share Posted December 22, 2004 Yeah it works if done properly. Turn the ignition key to on but DON'T start the engine. Buckle and unbuckle the driver's belt I think 10 or 15 times quickly then turn the ignition key to OFF without starting the car. The next time you start the car, the chime will sound 5 or 6 times and disregard anyhting about the passenger seat. It worked for my 05 OBi Ltd 6 months ago and has never returned. Good riddance to the nagging chime "reminding" me of what I already know, thank you very much! Link to comment Share on other sites More sharing options...
wcarey Posted December 26, 2004 Author Share Posted December 26, 2004 Thanks for the direction. As strange as it sounded that goofy procedure seems to have worked beautifully. Link to comment Share on other sites More sharing options...
rcoaster Posted December 26, 2004 Share Posted December 26, 2004 wcarey said: Thanks for the direction. As strange as it sounded that goofy procedure seems to have worked beautifully. You should see the other goofy procedures used to disable or change options for certain features in the car! I have a partial list of the technical manual for the 2005 Legacy and outback, and after looking over the manual, it appears that the 2005 Legacy/Outback uses a special computer communication network between all the computers in the car to simplify the wiring. I think there are two different "networks" the car uses, one called a "CAN" and the other called a "LAN". I'm not sure what they mean, but I'll have to look at the technical manual again to find out. RC. Link to comment Share on other sites More sharing options...
brus brother Posted December 26, 2004 Share Posted December 26, 2004 Any chance of letting the rest of us 05 owners find out what other mods and options are available to us? Can you cut and paste or otherwise post your discovery? Is there really a way of turning the windshield wiper into a fishing rod? Link to comment Share on other sites More sharing options...
