oldbodyDL Posted December 22, 2004 Share Posted December 22, 2004 I have a 78 EA71 in the the Machine Shop. After getting it all cleaned up, we found that there are some fine scatches on bottom of the cylinders. The Machinist checked that ovalization and found it is worn, however it is with in tolerance (bearly). I am near the end of my budget and worried about paying for the bore job and new pistons. If you were me, would you brake the budget and get the pistion/ bore job or would you let it slide ??????? Link to comment Share on other sites More sharing options...
Ross Posted December 22, 2004 Share Posted December 22, 2004 How far down the cylinder is it scratched? If it is right down the bottom, it isn't A big prob. If the bore is within manufacturers tolerance, it should be ok, but it really depends how fussy you are. It will certainly mean that the engine will not last as long before another recondition (and re-bore) is needed, but this may not be a prob, as it should still last well enough if it is serviced reguarly. The wear may cause the rings not to seat as well as they could, resulting mainly in slight oil consumption. If the bore is within manufacturers tolerances, the loss in compression should be negligable. Link to comment Share on other sites More sharing options...
archemitis Posted December 22, 2004 Share Posted December 22, 2004 im assuming the machinist doesnt think a ball hone will clean them up enough? you are reringing with new rings right? thats a tough call. i guess if they are within specs go for it =] Link to comment Share on other sites More sharing options...
rallyruss Posted December 22, 2004 Share Posted December 22, 2004 I would bore if you plan on keeping it for a while. or look for a block in better condition. depends on what your budget is I guess. Link to comment Share on other sites More sharing options...
erik litchy Posted December 22, 2004 Share Posted December 22, 2004 theres no doubt in my mind id bore it out the max. it costs no more than a smaller bore. Link to comment Share on other sites More sharing options...
mcbrat Posted December 22, 2004 Share Posted December 22, 2004 I have a set of 4 ea71 aftermarket pistons with rings. size is .030 over (30 over?) $50 plus shipping. Link to comment Share on other sites More sharing options...
archemitis Posted December 22, 2004 Share Posted December 22, 2004 yup, do that. bore it for sure and buy mcbrats pistons. Link to comment Share on other sites More sharing options...
rallyruss Posted December 22, 2004 Share Posted December 22, 2004 McBrat said: I have a set of 4 ea71 aftermarket pistons with rings. size is .030 over (30 over?) $50 plus shipping. thats a friggin great deal. I would jump on it if I were you. new from the dealer is outragous. I would say bore it and buy Mcbrats pistons and rings. Link to comment Share on other sites More sharing options...
ballitch Posted December 22, 2004 Share Posted December 22, 2004 damn $50 for EA-71 pistons and rings .030 over-sized, holys**t, buy those dude, if you dont your letting the best deal ever slip through your fingers. Link to comment Share on other sites More sharing options...
ShawnW Posted December 22, 2004 Share Posted December 22, 2004 Are the skirts of your pistons scratched up badly? If not I would say go with your block. Link to comment Share on other sites More sharing options...
