Vicious-S Posted December 22, 2004 Share Posted December 22, 2004 i just figured out that my car is an ea71 (i was wiping the dirt off of the engine and read "ea71") and was wondering if the chassis for the 1.6L is the same as the 1.8L, and if i can use the ozified 3"/3" lift on it. Link to comment Share on other sites More sharing options...
ezapar Posted December 22, 2004 Share Posted December 22, 2004 A search for "lift kit Gen 1" turned up this: http://www.ultimatesubaru.org/forum/search.php?searchid=51049Try a couple of searches, you can find oodles on the subject I'm sure. Link to comment Share on other sites More sharing options...
mcbrat Posted December 22, 2004 Share Posted December 22, 2004 i just figured out that my car is an ea71 (i was wiping the dirt off of the engine and read "ea71") and was wondering if the chassis for the 1.6L is the same as the 1.8L, and if i can use the ozified 3"/3" lift on it. if you have the 80-84 body style (and 85-87 Brats, 85-89 Hatchbacks), then yes, it will work. if you have the 72-79 body style (and 80-81 Brats), it will not work. Link to comment Share on other sites More sharing options...
Jibs Posted December 22, 2004 Share Posted December 22, 2004 if you have the 80-84 body style (and 85-87 Brats, 85-89 Hatchbacks), then yes, it will work. if you have the 72-79 body style (and 80-81 Brats), it will not work. How about 82-87 Brats? Link to comment Share on other sites More sharing options...
carfreak85 Posted December 22, 2004 Share Posted December 22, 2004 That falls into the 80-84 model range, so yes, it will work. Although if you plan on offroading it, then I would pu the 1800 engine in. Also that can't be the original engine because no USDM Gen 2 brats had 1600 to the best of my knowledge. Link to comment Share on other sites More sharing options...
