oddcomp Posted December 22, 2004 Share Posted December 22, 2004 so what are the part numbers eitehr o.e.m or aftermarket <felpro ect> for the gaskets for the water crossover passage on a spider intake the thing that runs between the lower intake runners/injector mounts i got the intake gaskets already but not those water crossover things and i need a throttle body gasket also i would rather not make my own Quote Link to comment Share on other sites More sharing options...
NorthWet Posted December 22, 2004 Share Posted December 22, 2004 Solution: Give everything to me and I'll make the gaskets. Problem solved!!! OK, I assume that you have talked to NAPA/whoever to see about intake gasket set for the proper year XT? Quote Link to comment Share on other sites More sharing options...
All_talk Posted December 22, 2004 Share Posted December 22, 2004 Yeah, should be available at the parts house, I think the year change for the spider was '87 1/2, an '88 XT intake "set" should do the trick. Gary Post whoring is complete... this should be 500... lol. Quote Link to comment Share on other sites More sharing options...
Marck Posted December 22, 2004 Share Posted December 22, 2004 These are OEM Part Numbers: Throttle Body Gasket for the Spider only: 16175aa080 "gaskets for the water crossover passage on a spider intake": 14072aa060 (not absolutely sure about this one and you want to order 2 of these) Quote Link to comment Share on other sites More sharing options...
Marck Posted December 22, 2004 Share Posted December 22, 2004 Here is some more: EGR valve gasket for Spider only: 14719aa000 How about a PCV Valve that should work with any of our EA82 cars: 11810aa000 Quote Link to comment Share on other sites More sharing options...
