spinsirs Posted December 23, 2004 Share Posted December 23, 2004 i was told when i bought my 79 brat that it had a e81 and a dual range transmission put into it. the 4wd locks into 2 places so im pretty sure it has dual range but when i went to the junk yard to get a newer carb they were all to big even from a 1987. if i do have a e71 where would i look to find a better performing carb? thanks in advacnce! Quote Link to comment Share on other sites More sharing options...
monstaru Posted December 23, 2004 Share Posted December 23, 2004 you can pick up a weber at redlineweber.com.or go to your local jy and find one on numerous cars.do a search on weber and start looking through it. Quote Link to comment Share on other sites More sharing options...
TheSubaruJunkie Posted December 23, 2004 Share Posted December 23, 2004 Look on the front of your engine block for either EA71 or EA81 stamped into it. It should be near the passenger side head. There are two types of EA81 carbs. Hitachi two barrel, and Carter-Weber one barrel. There are also Weber DGV 32/36 carbs that are an upgrade for the EA81. Might be too much carb if you have a EA71 however. -Brian Quote Link to comment Share on other sites More sharing options...
DaveAP Posted December 23, 2004 Share Posted December 23, 2004 I have a weber on my 1600, no problems. Quote Link to comment Share on other sites More sharing options...
swiftt Posted December 23, 2004 Share Posted December 23, 2004 I'm running a Weber on an EA71 too. I had to jet the secondary circuit leaner than what it came out of the box and advance the timing 2* but it runs well. Quote Link to comment Share on other sites More sharing options...
