EJ-25 - EZ-30 conversion?
bajavwnsoobnut
what would be hard is making a obd 1 motor run from a obd 2 wiring harness,that would be a PITA. the motor should fit, doesnt the EZ30 have the same bolt pattern as the EJ series motors? If so then it'll bolt right up.
~Josh~
Probably not. I seriously doubt the ECU and wiring harnes for an EJ25 will work with and EZ30. Another concern is the accesories: A/C compressor, PS Pump and alternator. They had to place them in different locations to fit the EZ30 in the engine compartment, so the bracket will need to swapt too, and hope they are compatible.
what I was talking about Craig was swaping out ECU's and if the wiring harness from the engine (EZ-30) connecting to the harness on the body is not a problem then that's what I am looking at and if need be we can get the correct a/c lines and such if my friend does decide to keep a/c and the other various systems will be plumbed accordingly
  • 2 weeks later...
