mtnman38 Posted December 24, 2004 Share Posted December 24, 2004 Hey all Its time for another retro question. OK did subaru in any of thier models offer a locker for the rear end if so what model is it? Do they have one with a locker for the front wheels incased in the trans and would the parts go into a 84 ea81 4wd dual range 5 speed with ea82 rear end? If I am, just dreaming (about stock subaru lockers) what or where might I find a solution for locking the suby Thanks LT Link to comment Share on other sites More sharing options...
GLCraig Posted December 24, 2004 Share Posted December 24, 2004 Nope Subaru never made a locker. The closes you'll find is a rear limited slip. Link to comment Share on other sites More sharing options...
TheSubaruJunkie Posted December 24, 2004 Share Posted December 24, 2004 Rear LSD's are available on RX's and very few GL10's. There were never any front LSD or front lockers. -Brian Link to comment Share on other sites More sharing options...
nkx Posted December 24, 2004 Share Posted December 24, 2004 *Bling* ive got a center locking diff on the buggy Link to comment Share on other sites More sharing options...
Scoobywagon Posted December 24, 2004 Share Posted December 24, 2004 A friend and I have been working (intermittently) on reverse engineering a lock-rite to fit the R160. I'll be sure to post when (if) we get some results. Link to comment Share on other sites More sharing options...
coloradosubarules Posted December 24, 2004 Share Posted December 24, 2004 You could search long and hard for the rear axle assembly from a 91 turbo legacy with the VLSD rearend. Then you could find a way to stuff it under your rearend. Hope this helps.. Link to comment Share on other sites More sharing options...
TheSubaruJunkie Posted December 24, 2004 Share Posted December 24, 2004 Locking center diff and locking front/rear diff are 2 different things. My RX has a locking center diff. My Wagon has no center diff. My Legacy has an open center diff. -Brian Link to comment Share on other sites More sharing options...
MilesFox Posted December 24, 2004 Share Posted December 24, 2004 i have heard of lsd's being swapped into front diffs, but i dont know what's all involved. Link to comment Share on other sites More sharing options...
mtnman38 Posted December 25, 2004 Author Share Posted December 25, 2004 Thanks all for the Intel What are the advatages of having a rx center lock diff? Link to comment Share on other sites More sharing options...
MorganM Posted December 25, 2004 Share Posted December 25, 2004 Subaru never made one but Lincoln makes one for Subaru Link to comment Share on other sites More sharing options...
TheSubaruJunkie Posted December 25, 2004 Share Posted December 25, 2004 With the RX Center diff open, the power isnt really sent to the front or rear. Its sent to whichever end has the least amount of traction... just like any open diff would. With it locked, it sends power 50/50 front and rear, like a locked diff would. A 4WD EA82 has no center diff. When you put your car into 4WD, its 50/50 like a locked diff would act. -Brian Link to comment Share on other sites More sharing options...
Qman Posted December 25, 2004 Share Posted December 25, 2004 coloradosubarules said: You could search long and hard for the rear axle assembly from a 91 turbo legacy with the VLSD rearend. Then you could find a way to stuff it under your rearend. Hope this helps.. That would be a direct bolt in! Link to comment Share on other sites More sharing options...
mtnman38 Posted December 25, 2004 Author Share Posted December 25, 2004 coloradosubarules said: You could search long and hard for the rear axle assembly from a 91 turbo legacy with the VLSD rearend. Then you could find a way to stuff it under your rearend. Hope this helps.. How could I tell if it has this rearend by looking at it ? Do all 91 turbo legacys have this rear end whats the v stand for? variable? Thanks LT Link to comment Share on other sites More sharing options...
TheSubaruJunkie Posted December 25, 2004 Share Posted December 25, 2004 THe V stands for Viscious and any '91 Turbo Legacy should have one. I dont think the Automatics got them, but i could be wrong. The rear end of the diff will be tagged as 3.9 LSD or maybe VLSD. -Brian Link to comment Share on other sites More sharing options...
SKIPPYH2O Posted December 11, 2011 Share Posted December 11, 2011 (edited) mtnman38 said: Hey all Its time for another retro question. OK did subaru in any of thier models offer a locker for the rear end if so what model is it? Do they have one with a locker for the front wheels incased in the trans and would the parts go into a 84 ea81 4wd dual range 5 speed with ea82 rear end? If I am, just dreaming (about stock subaru lockers) what or where might I find a solution for locking the suby Thanks LT Not any companies, but this will and should help you to understand. And I will be working with my machinist buddy to create a mini spool for my '82 brat. once that is programmed, I will post it Skip out! http://www.awdwiki.com/en/subaru/ Edited December 11, 2011 by SKIPPYH2O forgot link. Link to comment Share on other sites More sharing options...
monstaru Posted December 17, 2011 Share Posted December 17, 2011 SKIPPYH2O said: Not any companies, but this will and should help you to understand.And I will be working with my machinist buddy to create a mini spool for my '82 brat. once that is programmed, I will post it Skip out! http://www.awdwiki.com/en/subaru/ Look at the date on the post .This thread is almost 8 yrs old. No need to make a spool.Just weld it if that is what you want. cheers Link to comment Share on other sites More sharing options...
bheinen74 Posted December 18, 2011 Share Posted December 18, 2011 All 1991 Turbo Legacy got the VLSD standard, automatics, 5speeds, every single one it was Standard equipment, ONLY for year 1991. It was not even optional on the 92-94, could not even be special ordered on 92+ since we have bumper the dead, thread of past, might as well add real facts. Link to comment Share on other sites More sharing options...
