Oh I used a Y-pipe from a 97 Legacy with an EJ22. It will bolt right up to a 1st gen midpipe and hanger. I plugged the second O2 sensor with an old O2 sensor and cut the wire off of it.
There are 2 down sides when doing this.
1. You end up with 3 catalytic converters, since the OBDII y-pipes have 2 cats and an 1st Gen Mid pipe has 1. At some point I'm going to check and see if I can find a later Legacy midpipe that dosen't have a catalytic converters and see if it will bolt right in.
2. The OBD11 Y-pipe is between 1 and 2 inches longer so it shifts the midpipe and muffler back some. For the most part you won't notice this. I didn until I bolted on a trailer hitch. If I put a load on the engine for an extended peroid, the muffler will expand enough to rub the hitch.
