smgjmg Posted December 26, 2004 Share Posted December 26, 2004 Can a 86 stock carberator handle the water if you are out wheelin, or do you need to step up and get a webber carb. And also is there any snorkles available for our carbed roos. Link to comment Share on other sites More sharing options...
MilesFox Posted December 26, 2004 Share Posted December 26, 2004 the stock air cleaner assembly is pretty water proof on its own. you would only need a snorkel if you are driving in floods or crossing water as high as the hood. you would have to invent a snorkel, and have to ditch the stock air cleaner for the most part Link to comment Share on other sites More sharing options...
smgjmg Posted December 26, 2004 Author Share Posted December 26, 2004 Thanks... the stock air cleaner assembly is pretty water proof on its own. you would only need a snorkel if you are driving in floods or crossing water as high as the hood. you would have to invent a snorkel, and have to ditch the stock air cleaner for the most part Link to comment Share on other sites More sharing options...
