subpennyman Posted December 26, 2004 Share Posted December 26, 2004 Does anyone have a link to a schematic/wiring diagram for a 1993 Loyale 4door Wagon- manual transmission? I need some help! Fuel is not getting delivered through the Injector! I also have an issue with my parking lights not turning off and I cannot find the connector to plug the Code Reader into! So a wiring diagram would go a long ways towards helping me. thanks. sub Link to comment Share on other sites More sharing options...
Cougar Posted December 26, 2004 Share Posted December 26, 2004 I have a drawing for an '88 model that may be close to your model. One thing that can cut the fuel delivery is the lack of spark. Have you checked that spark is occuring while this problem happening? As far as your parking lights staying on I would check the light switch on the top of the steering column to see it that is on. Link to comment Share on other sites More sharing options...
hush777 Posted December 26, 2004 Share Posted December 26, 2004 Cougar's diagram should work for all of your system except the auto seatbelt stuff. The signal for the injectors to open comes from the ditributor and the ignitor. Hush Link to comment Share on other sites More sharing options...
brus brother Posted December 26, 2004 Share Posted December 26, 2004 http://www.main.experiencetherave.com:8080/subaru_manual_scans/ The above link (courtesy of Moderator Legacy777) is for a variety of FSM including electrical for 92. Might be of help. I wish these type documents could be gathered together and made available more obviously in Repair and Mods or under their own heading! Santa, are you still around? Link to comment Share on other sites More sharing options...
subpennyman Posted December 26, 2004 Author Share Posted December 26, 2004 Can you post the diagram that you have or email it to me at scottyd9@nventure.com. I appreciate your help. Link to comment Share on other sites More sharing options...
hush777 Posted December 26, 2004 Share Posted December 26, 2004 BTW Your loyale is considered a old gen wagon as it is the ea82 body style. New Gen is legacy, impreza, outback, forester stuff. Hush Link to comment Share on other sites More sharing options...
Cougar Posted December 26, 2004 Share Posted December 26, 2004 I can try to scan it a send it to you. Do you know if the engine is getting spark? Link to comment Share on other sites More sharing options...
subpennyman Posted December 26, 2004 Author Share Posted December 26, 2004 The engine will start and run for about 2-3 seconds- If raw gas is poured down the throat of the carb, it will stay running unti my small can of fuel is used up. Link to comment Share on other sites More sharing options...
Cougar Posted December 26, 2004 Share Posted December 26, 2004 So the ignition is ok then. You may have a bad fuel pump. One easy thing you can do is to see if the pump is running is to turn the key to the run position and listen for a slight hum from the pump motor as it charges the system. This will only happen for a couple of seconds. You may have to try to start the engine and then turn the key off and then to on and listen if the pressure is up already. Link to comment Share on other sites More sharing options...
subpennyman Posted December 26, 2004 Author Share Posted December 26, 2004 I can hear the pump run and have loosened the clamp on the fuel line at the Injector- Fuel squirts out! Link to comment Share on other sites More sharing options...
Cougar Posted December 26, 2004 Share Posted December 26, 2004 It seems that the injector is not opening for some reason then. This could be because the signal is not getting to the injector or the injector is bad. Do you have a multimeter to check this out and know what to check for? Link to comment Share on other sites More sharing options...
Cougar Posted December 26, 2004 Share Posted December 26, 2004 Please Standby, Owners Are Checking Their Vehicles. Link to comment Share on other sites More sharing options...
Cougar Posted December 26, 2004 Share Posted December 26, 2004 Did you read my post #11 Subpennyman? Link to comment Share on other sites More sharing options...
subpennyman Posted December 26, 2004 Author Share Posted December 26, 2004 I have a multimeter and know how to use it. Just let me know what pins to check and what resistance should I be looking for? I also found a '92 subaru manual. It talks about performing various checks (U-check,read memory, and D-check) using test mode and read memory plugs coinciding with flashing of check engine and O2 light. Going to run the tests now. Be back shortly Thanks Sub Link to comment Share on other sites More sharing options...
Cougar Posted December 26, 2004 Share Posted December 26, 2004 Great! Things should be going good now. I'm not real sure what the resistance of the injector coil should be but I seem to recall it is around 70 ohms and if you have a reading close to that then I would think that the injector is most likely ok and then check the signal to it. I assume that this engine only has one injector and is not multipoint injected. If you want to check the voltage getting to the injector then you could remove the lead and check the DC voltage while trying to start the engine. Not sure what the meter will read as this will be DC pulsing signal but I would guess around 5 volts. Did you check your light switch on the steering column? Link to comment Share on other sites More sharing options...
subpennyman Posted December 26, 2004 Author Share Posted December 26, 2004 Reading 5 volts on 2 pair of wires in the harness going to the single injector. The resistance on the injector- dont have precise readings but assuming there should be 2 coils of resistance to match the harness wiring- one coil has a higher reading than the other. Havent had time to look at the light issue- in fact laights dont matter if the car doesnt move!? Sub Link to comment Share on other sites More sharing options...
Cougar Posted December 26, 2004 Share Posted December 26, 2004 What were the readings of the two coils? Edit: As far as the light switch is concerned. If the lights are staying on while the vehicle is off then you really do need to check that switch position on top of the steering column. Link to comment Share on other sites More sharing options...
Cougar Posted December 26, 2004 Share Posted December 26, 2004 While waiting for your response I got out my manual and it only shows one pair of wires going to the injector. These tie to pins 43 and 48 of the SPFI unit. Link to comment Share on other sites More sharing options...
subpennyman Posted December 26, 2004 Author Share Posted December 26, 2004 Light problem fixed. ID 10 T error. It was the switch-operator error. Injector problem: (1 Wire bundle - 4 wires 4 pins.) One set has higher resistance than the other. Note: red light on ECU is flashing 5 rapid flashes. I couldn't find the test connectors mentioned in the '92 series repair manual. Not sure if the '93 has the same configuration. Not sure if this helps, but there is a two wire device with vacuum lines running to it- it was clicking about every 1.5 seconds- has a black round cap(?) that can be rotated- on left side of engine on top of intake manifold just to the right of the front left cylinder. BTW- the wiring diagram we have been working with is for a Legacy-we have a Loyale. Sub and son Link to comment Share on other sites More sharing options...
Cougar Posted December 26, 2004 Share Posted December 26, 2004 What was the resistance of each of the coils? I assume that the harness is removed while taking the reading. Link to comment Share on other sites More sharing options...
subpennyman Posted December 26, 2004 Author Share Posted December 26, 2004 I am unable to get good readings on my hand held VOM. The X1 scale cannot be adjusted for zero ohms with the leads shorted! My x100 scale works ok and I get 4400 on one coil pair and a short on the other pair. Harness is removed. Sub Link to comment Share on other sites More sharing options...
subpennyman Posted December 26, 2004 Author Share Posted December 26, 2004 Let me run some extension cords and take my digital 60 cycle DVM out and get some good #'s- Stand by. Sub. Link to comment Share on other sites More sharing options...
subpennyman Posted December 26, 2004 Author Share Posted December 26, 2004 .12 ohms on the upper pair and 4.4k ohms on the lower pair. Link to comment Share on other sites More sharing options...
Cougar Posted December 27, 2004 Share Posted December 27, 2004 As far as the ECU codes, I think that five pulses are normal and it means there are no troubles reported. Not certain on that though. Link to comment Share on other sites More sharing options...
Cougar Posted December 27, 2004 Share Posted December 27, 2004 Wow, those resistance readings are not anything like I would expect. Does your manual say anything about what the readings should be? It sounds like the injector is bad but I would try to verify that against a new one if possible. To fix your ohmmeter you need a new battery that is used for the lower scale readings. The battery voltage is too low to set the zero on it. Link to comment Share on other sites More sharing options...
