87+ Fuel Cut Solution
WJM
Just a thought for you. Most cars made since the late 80's have a "Fuel Cut" in them for accidents. A device somewhere sees a big enough shock and it kills power to the fuel pump. This is most likely what the box is you are searching out and it probably has nothing to do with overboost. If I remember correctly from what I read years ago the ECU senses the overboost and shuts down Injectors. Also, I believe the ECU senses the overboost based on readings from the MAF based on RPM.
Keith
